2 Replies Latest reply on Jul 5, 2017 5:31 AM by Megnj469
    OCR and embed fonts
    Megnj469 Level 1
      Hi, I need to OCR AND embed fonts. I have Acrobat Pro DC. The 2 actions seem to be mutually exclusive. If I get my fonts embedded (e.g. through using distilled or saving as PDF/A, then OCR undoes the embedding. If I do OCR first, I am afraid I am losing the OCR when I then embed the fonts. i don't know how to check that but document resolution does seem to go way down. If I do a second OCR step, I identify new text that needs fixed. What should I do?
        • 1. Re: OCR and embed fonts
          Certainly. If you can OCR at all after making a PDF containing actual text - most versions of Acrobat refuse to do so - then your entire page is turned back to bitmap for OCR. Everything to do with fonts, all vector graphics, are lost. This is not something to be done late in the process or on only part of a page.
          OCR embeds fonts if it needs to. You do not need to do it later and may cause damage or find it impossible. When you OCR with hidden text, no fonts needs to be embedded because it is invisible; PDF/A and PDF/X recognise and allow this special case.
          OCR once. OCR only scanned information, not anything else. OCRing just graphics in a page is not a practical proposition.
          • 2. Re: OCR and embed fonts
            Megnj469 Level 1
            Thank you! Very helpful!
