2 Replies Latest reply on Jul 4, 2017 1:46 AM by frankema
    Print Date in Header
    frankema Level 1
      Hi Folks,
      Since I have to do a lot of "klicking Work" with Scanned PDF, I was wondering if there is a posibility to maximum Automation.
      What I have to do with a scanned main document with appendices (in one document):
      1. OCR
      2. C&P a dynamic formular field out of a template named "Heute" (engl. "Today") -> Put this in Header on any page (I use the site spanning tool)
      3. open JS Editor -> document action -> "on print" and typ in the code:
      var f = this.getfield("Today"); f.value="Printdate:"+util.printd("dd.mm.yyyy",newDate());
      -> This works fine
      4. Safe and crypt it to "print only" rights
      Ok here is my Point: .
      For Point 1, 3 and 4 the "Action Assistent" (Aktionsassistent in ger.) works very well for me. So ist there a posibility to put in the formular field automatically, always on the same position? I can't find it in the options of the action Assistent.
      OR: Kind of a JS Code to generate such a field?
      Another Problem: If I try on Point 2, not to use the c&p field from the template but generate manually a new one with exactly the same conditions like the template, the code won't work. Why ?
      Thanks for help!
