• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Correct settings for exporting jpg
Explorer ,
Jul 03, 2017 Jul 03, 2017
I'm exporting a collection of jpeg shot in light room five to a usb thumb drive so I can make paper prints at a store.Could someone kindly
tell me the settings that will get me the maximum quality in a print for the following: quality, limiting file size, resolution and pixels per inch? Please give me numbers.
Is there a default setting for all of them? That is to say, is there an average normal setting.
I have no idea what number to use---whether I should put down 1000 for file size or what. Kelby's book doesn't seem to mention it.
Al Marotta
[Title changed by Moderator]
Views
340
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jul 04, 2017 Jul 04, 2017
First, do not limit the file size - un-check this.
Depending on the print lab you probably need to use a JPG. Set quality to 90%, select sRGB Color Space and you can leave Resolution at it's default of 240 (IIRC) as it doesn't matter when you tell the lab the size you want it to be printed.
Un-check Resize to Fit and select Sharpen For Print.
The lab will print the resulting file to the size you tell them.
For more sophisticated labs, there is an advantage to use TIFF and AdobeRGB - but you need to
Votes
Translate
Translate
Community Expert ,
For more sophisticated labs, there is an advantage to use TIFF and AdobeRGB - but you need to make sure they know how to handle these files.
--- Got your issue resolved? Please label the response as 'Correct Answer' to help your fellow community members find a solution to similar problems. ---
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Thanks for your great help on this matter. It really helped to end an
anxiety creating matter.
Al Marotta
Votes
Translate
Translate
Report
Report
