제목이 질문입니다...
Message was edited by: Mod (Discussion successfully moved from The Lounge to Photoshop General Discussion)
Adobe is no longer updating CS6 software but you will be able to use the free DNG converter to batch convert cr2 files into DNG which will then work in CS6. However your camera is very new and you will need to wait for Adobe to update the DNG converter application. In the meantime, if you can’t wait, you could use the Canon DPP software on your EOS disk to edit/convert CR2 to tiff and then use the tiff files in CS6
Unless I am misreading the translation - the question is about the Canon 7D MkII. This just needs ACR version 8.7 or later and should therefore be supported in ACR 9.1.1. which is compatible with CS6 and can be downloaded here:
Camera Raw installer for Adobe Photoshop CC and CS6
Dave
You are right Dave. It is the 6D MkII that has just been released.
