1. Re: Scaling from center anchor point???
Semaphoric Jul 3, 2017 5:47 PM (in response to marcdcx)What happens when you do this? It works just like always for me on Windows.
2. Re: Scaling from center anchor point???
JJMack Jul 3, 2017 8:52 PM (in response to marcdcx)On Windows Alt transforms from center. Shift Constrains the transform . For example the Aspect ratio to the current aspect ratio, or to a square or circle. They can be used together and a corner control point must be use to drag transform being done.
3. Re: Scaling from center anchor point???
Trevor.Dennis Jul 3, 2017 9:08 PM (in response to marcdcx)What is your workflow? Are you working from the Move tool with Show Transform Controls checked, or using Free Transform directly? Just to be clear, you are dragging the _corner_ handles together with Opt and Shift, and not the mid handles?
I take it you have checked those Shortcuts are set to the defaults? A custom set would show in the Edit > Keyboard Shortcuts dropdown. For instance, I switch to the Essentials workspace when I need to use the defaults.
Do you have any plug-ins that might have stolen the shortcut focus? Font managers... that sort of thing?
Do you have any other processes running outside Photoshop that might have stolen the shortcut focus? Screen grabbers for instance.
4. Re: Scaling from center anchor point???
dfasfsadfasdfsadf15s Jul 27, 2017 5:37 PM (in response to marcdcx)I, too, am going insane after updating. Did you ever figure this out?
5. Re: Scaling from center anchor point???
davescm Jul 28, 2017 5:35 AM (in response to dfasfsadfasdfsadf15s)Hi
Shift (Constrain) + Alt (from Centre) is for Windows. I am not a Mac user, but understand the Mac equivalents to be Shift and Opt
Default keyboard shortcuts in Adobe Photoshop
Dave
6. Re: Scaling from center anchor point???
dfasfsadfasdfsadf15s Jul 28, 2017 7:12 AM (in response to davescm)Thanks, Dave.
I actually figured this out. It was the latest Wacom tablet drivers that were the culprit. For whatever reason, they disabled the usual keyboard shortcut for this.
I just went to the Wacom website and reinstalled older drivers and the problem fixed itself. I use a Wacom Intous3.
7. Re: Scaling from center anchor point???
davescm Jul 28, 2017 7:26 AM (in response to dfasfsadfasdfsadf15s)Thanks for posting that - it may help others
Dave
8. Re: Scaling from center anchor point???
Martin_Bns Jul 28, 2017 8:12 AM (in response to marcdcx)Hi, it works perfectly. Please check if there is any other software taking over your usual Shortcuts.
All my best mate,Martin
