1 Reply Latest reply on Jul 5, 2017 12:12 PM by kerrishotts
    i can not get to build
    stamk19118890
      App ID
      842985
      it worked just fine few weeks ago, today i entered the pass again, and then i got this error in compilation. i need some help.
      Build Date: 2017-07-04 15:27:06 +0000
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preReleaseBuild UP-TO-DATE
      :checkReleaseManifest
      :preDebugBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:compileReleaseAidl
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:processReleaseManifest
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportSupportCompat2520Library
      :prepareComAndroidSupportSupportCoreUi2520Library
      :prepareComAndroidSupportSupportCoreUtils2520Library
      :prepareComAndroidSupportSupportFragment2520Library
      :prepareComAndroidSupportSupportMediaCompat2520Library
      :prepareComAndroidSupportSupportV42520Library
      :prepareComGoogleAndroidGmsPlayServicesBase1100Library
      :prepareComGoogleAndroidGmsPlayServicesBasement1100Library
      :prepareComGoogleAndroidGmsPlayServicesGcm1100Library
      :prepareComGoogleAndroidGmsPlayServicesIid1100Library
      :prepareComGoogleAndroidGmsPlayServicesTasks1100Library
      :prepareComPushbotsPushbotsLib302Beta3Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :compileReleaseAidl
      :mergeReleaseAssets
      :mergeReleaseResources
      :compileReleaseSources
      :prePackageMarkerForRelease
      :transformClassesWithDexForRelease
      Merged dex #1 (86 defs/108.4KiB)
      Merged dex #2 (691 defs/606.0KiB)
      Merged dex #3 (138 defs/248.9KiB)
      Merged dex #4 (70 defs/100.0KiB)
      Merged dex #5 (74 defs/180.4KiB)
      Merged dex #6 (221 defs/221.8KiB)
      Merged dex #7 (1 defs/0.7KiB)
      Merged dex #8 (307 defs/273.6KiB)
      Merged dex #9 (323 defs/248.1KiB)
      Merged dex #10 (25 defs/41.0KiB)
      Merged dex #11 (7 defs/21.6KiB)
      Merged dex #12 (44 defs/30.3KiB)
      Merged dex #13 (36 defs/51.0KiB)
      Merged dex #14 (201 defs/320.4KiB)
      Merged dex #15 (43 defs/82.7KiB)
      Merged dex #16 (84 defs/102.4KiB)
      Merged dex #17 (47 defs/8.8KiB)
      Result is 2398 defs/3163.1KiB. Took 0.1s
      :transformResourcesWithMergeJavaResForRelease FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':transformResourcesWithMergeJavaResForRelease'.
      > com.android.build.api.transform.TransformException: com.android.builder.packaging.DuplicateFileException: Duplicate files copied in APK META-INF/maven/com.squareup.okio/okio/pom.xml
        File1: /gradle-home/caches/modules-2/files-2.1/com.squareup.okio/okio/1.13.0/a9283170b7305c8d92d 25aff02a6ab7e45d06cbe/okio-1.13.0.jar
        File2: /project/build/intermediates/exploded-aar/com.google.android.gms/play-services-basement/1 1.0.0/jars/classes.jar
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 4.617 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
        • 1. Re: i can not get to build
          kerrishotts Adobe Employee
          It sounds like you've got two plugins that are colliding. Look for anything google related & squareup related and take one of those out to see if the build works then. (Your app probably won't, but you can address that after determining which plugin is causing the build itself to fail.)
