2 Replies Latest reply on Jul 5, 2017 1:06 PM by jacc84044376
    Andriod build not working
    jacc84044376 Level 1
      Getting the following error:
      Build Date: 2017-07-04 17:12:38 +0000
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      FAILURE: Build failed with an exception.
      * What went wrong:
      A problem occurred configuring root project 'project'.
      > You have not accepted the license agreements of the following SDK components:
        [SDK Patch Applier v4, Google Repository].
        Before building your project, you need to accept the license agreements and complete the installation of the missing components using the Android Studio SDK Manager.
        Alternatively, to learn how to transfer the license agreements from one workstation to another, go to http://d.android.com/r/studio-ui/export-licenses.html
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 2.33 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
