1. Re: Sort spreads alphabetically INDD CS6 or CC
Jump_Over Jul 4, 2017 3:02 PM (in response to sw52308871)Hi,
Assuming you are merging 2 files (single spread):
- Angola, Benin
- Argentina, Barbados
What is your final goal? How your merged file should be sorted?
Jarek
2. Re: Sort spreads alphabetically INDD CS6 or CC
sw52308871 Jul 4, 2017 7:27 PM (in response to Jump_Over)Hi Jarek,
The 4 files are all 2-page spreads. Each country has 2 pages of data, with a left and a right page (the data includes tables and charts). My final goal is to have all of the spreads in alphabetic order - so it would be "Angola, Argentina, Bangladesh, Barbados, Belize, Benin, Bhutan, Botswana, Cambodia etc." - with 2 pages for each.
The problem is the 2-page spreads. Each file has a 2-page master, with mirrored margins and wider inside margins than outside. Teh left-hand pages need to stay on the left, followed by the right-hand pages. Each page has the country name at the top, in a paragraph style (so Angola has "Angola" at the top of both of the 2 pages).
Sam
3. Re: Sort spreads alphabetically INDD CS6 or CC
Jump_Over Jul 5, 2017 12:27 AM (in response to sw52308871)Hi,
OK. I missed you wrote '2-page spreads with per-country', sorry.
Have you made any try with a code? How your files become merged?
Is the only way to find 'country' as a top page textFrame content?
What about page names? What about paragraphStyle name? Do your 'country' (and ONLY your 'country') use a specific style?
Jarek
4. Re: Sort spreads alphabetically INDD CS6 or CC
sw52308871 Jul 5, 2017 5:18 AM (in response to Jump_Over)Thanks Jarek,
I've merged the files manually - there are only 4.
I've tried with this script, which works, but the spreads are often swapped over, with right-hand pages moved to the left: "Script to sort Pages according to alphabetical order of their top TextFrames contents" by Trevor at https://forums.adobe.com/message/6115260#6115260
Yes, the "country" title has its own, unique paragraph style, so I'll try paragraphStyle instead of top page textFrame. Thanks for the suggestion (I'm not at the right Mac here, but will let you know when I've tried)
Sam
5. Re: Sort spreads alphabetically INDD CS6 or CC
Trevorׅ Jul 5, 2017 7:13 AM (in response to sw52308871)1 person found this helpfulWell as the world authority on that script does this one do what you want?
// Script to sort spreads according to alphabetical order of their top TextFrames contents // by Trevor (www.creative-scripts.com) custom and readymade scripts for InDesign // https://forums.adobe.com/thread/2354151 // http://forums.adobe.com/thread/1405293?tstart=0 // see also http://forums.adobe.com/thread/1082984?tstart=0 for a better workflow app.doScript("aToZPageSort()", ScriptLanguage.javascript, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "Sort Pages By top text contents"); function aToZPageSort() { var doc, myPageIndex, l, topFrameIndex, z, pageFramesTops, i, topFrameHeight, getSpread; doc = app.documents[0]; myPageIndex = []; l = doc.spreads.length; topFrameIndex = z = 0; getSpread = function(f) { var saftey = 100; while ((f.constructor !== Spread) && saftey--) { f = f.parent; } return f; }; while (l--) { pageFramesTops = doc.spreads[l].textFrames.everyItem().getElements().slice(0); n = i = pageFramesTops && pageFramesTops.length; if (!i) continue; while (n--) pageFramesTops[n] = pageFramesTops[n].geometricBounds[0]; // for some reason when one trys to get the geometricBounds[0] from teh everyItems without the elements it return y1, x1 and not just y1 ?-) topFrameHeight = pageFramesTops[0]; topFrame = doc.spreads[l].textFrames[0]; for (var n = 0; n < i; n++) { if (pageFramesTops[n] < topFrameHeight) { topFrameHeight = pageFramesTops[n]; topFrame = doc.spreads[l].textFrames[n]; } } myPageIndex[z++] = { spread: getSpread(topFrame), contents: topFrame.contents.toLowerCase() }; } myPageIndex.sort(function(a, b) { return (a.contents.toLowerCase() > b.contents.toLowerCase()); }); l = myPageIndex.length; while (l--) myPageIndex[l].spread.move(LocationOptions.AT_BEGINNING); }
Trevor
6. Re: Sort spreads alphabetically INDD CS6 or CC
Trevorׅ Jul 5, 2017 7:29 AM (in response to sw52308871)1 person found this helpfulI do prefer this workflow
///////////////////////////////////////////////////////////////////////////////////// // Script by Trevor to sort Spreads according to alphabetical order of Page Headers // // http://creative-scripts.com // // https://forums.adobe.com/message/9686292#9686292 // // adapted from http://forums.adobe.com/thread/1082984?tstart=0 // // make sure to change to the write paragraphs style // // This assumes that you use a Paragraph style for your header // // AND THERE IS ONLY ONE HEADER ON EACH PAGE WHICH IS ONLY ONE PARAGRAPH LONG // ////////////////////////////////////////////////////////////////////////////////////// app.doScript("aToZSpreadSort()", ScriptLanguage.javascript, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "Sort Spreads text style contents"); function aToZSpreadSort() { var doc = app.documents[0], myHeaders, l, getSpread; getSpread = function(f) { var saftey = 100; while ((f.constructor !== Spread) && saftey--) { f = f.parent; } return f; }; app.changeGrepPreferences = app.findGrepPreferences = null; app.findGrepPreferences.appliedParagraphStyle = "My Header"; // Change above to the name of header style myHeaders = doc.findGrep(); myHeaders.sort(function(a, b) { if (a.contents.toLowerCase() > b.contents.toLowerCase()) return 1; else if (a.contents.toLowerCase() < b.contents.toLowerCase()) return -1; return 0; }); l = myHeaders.length; while (l--) getSpread(myHeaders[l].parentTextFrames[0]).move(LocationOptions.AT_BEGINNING); }
7. Re: Sort spreads alphabetically INDD CS6 or CC
Jump_Over Jul 5, 2017 10:17 AM (in response to sw52308871)1 person found this helpfulHi,
I suggest something similar but different findText() target -- just to decrease count of moved Spreads:
var mDoc = app.activeDocument, mSpreads = mDoc.spreads.everyItem().getElements(), mSpreadsArray = [], mParaStyle = mDoc.paragraphStyles.item("Title"), cFind, cCountry, cSpread, step; // |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||| app.doScript( main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "sortSpreads" ); function main () { app.findTextPreferences = null; app.findTextPreferences.appliedParagraphStyle = mParaStyle; while (cSpread = mSpreads.pop()) { cFind = cSpread.textFrames.everyItem().findText(); step = cFind.length; cFind.sort(); while (step--) { if (!cFind[step].length) continue; cCountry = cFind[step][0].contents; mSpreadsArray.push([cCountry, cSpread]); break; } } mSpreadSort(mSpreadsArray); app.findTextPreferences = null; // ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||| } function mSpreadSort (cSpreadsArray) { cSpreadsArray.sort(sortDoubleArray); var cSpread; while (cSpread = cSpreadsArray.pop()) { cSpread = cSpread[1]; cSpread.move(LocationOptions.AT_BEGINNING); } } function sortDoubleArray(a,b) { return a[0] > b[0]; }
Notice that var mParaStyle need to update a proper style name.
Jarek
8. Re: Sort spreads alphabetically INDD CS6 or CC
sw52308871 Jul 5, 2017 5:42 PM (in response to Trevorׅ)Thanks so much Trevor! That worked perfectly!!
Now I'm going to have to parse it carefully so that I can learn something here.
Sam
9. Re: Sort spreads alphabetically INDD CS6 or CC
sw52308871 Jul 5, 2017 5:45 PM (in response to Trevorׅ)For some reason I couldn't get this to work in INDD CS6 - but I'm going to try it on CC. My files didn't have headers but I can see this would be a great way around the problem if the spreads didn't all have the key word in the top frame.
Thanks Trevor.
10. Re: Sort spreads alphabetically INDD CS6 or CC
sw52308871 Jul 5, 2017 5:48 PM (in response to Jump_Over)Thanks for this Jarek! Trevor's first reply solved my current issue, but I like the idea of reducing the number of moved spreads. I tried this on CS6, and will try it on CC too - I think I may have just not let it run long enough! I'll let you know how I go.
