4 Replies Latest reply on Jul 6, 2017 11:46 PM by tarnumk57253864
    How to Merge or Synchonize cordova plugins with my application code
    tarnumk57253864
      Dear sir,
      Currently I am working on push notification. by default I have created hybrid app.
      Current Scenario is i am sending push notification from Firebase console to any registered device through package. Now i want to implement this in my project i.e in my hybrid application.I am using AWS EC2 and my all files are placed there. so how can i use existing cordova plugins in my web based application.
      I am using core java language, css,js,ajax,json.
        • 1. Re: How to Merge or Synchonize cordova plugins with my application code
          kerrishotts Adobe Community Professional
          I'm not entirely clear on what you're trying to accomplish, so it might help to know more about how your app is structured. From my (perhaps incorrect) understanding, you're trying to use Cordova plugins in a web app? That won't work -- Cordova plugins are only made to work with hybrid apps built with Cordova.
          If you have built your app with Cordova, then you should just be able to find a push plugin that's to your liking and follow the instructions in that plugin's repository.
          Side question: by "java" I presume you mean "javascript" ?
          • 2. Re: How to Merge or Synchonize cordova plugins with my application code
            tarnumk57253864 Level 1
            Thanks alot for your reply, Now actually i am facing below problem, above is solved.
            My hybrid app is getting browser based notification and not receiving push notification.
            as per below attached screenshot, when an alert or alarm is getting generated, notification(alert) is coming in attached screenshot format, but i want to receive it in push notification pop-up format.
            When my app is running in background or closed, there is no push popup is receiving.
            Thanks in advance.
            • 3. Re: How to Merge or Synchonize cordova plugins with my application code
              Not entirely sure what you're asking, but regarding push, if your app is in the foreground, it's up to your app to render the push -- the OS won't do it for you. The only time the OS will render the push notification is if your app is not running or is backgrounded. As to why the latter may not be working, you'd need to share code, config.xml (minus secret/identifying info), what plugin you're using, and what error messages, if any, you're getting.
              • 4. Re: How to Merge or Synchonize cordova plugins with my application code
                Thanks ..
                I have added following plugins
                1.cordova-plugin-console,dialogs,inappbrowser,statusbar,whitelist,
                2. phonegap-plugin-push.
                Here is my config.xml code::
                <?xml version='1.0' encoding='utf-8'?>
                <widget id="org.ems.sample" version="1.0.0" xmlns="http://www.w3.org/ns/widgets" xmlns:gap="http://phonegap.com/ns/1.0">
                    <name>appSample</name>
                    <description>
                        Push sample application that receives push notifications.
                    </description>
                    <author email="support@phonegap.com" href="http://phonegap.com">
                        PhoneGap Team
                    </author>
                    <content src="index.html" />
                    <preference name="DisallowOverscroll" value="true" />
                    <preference name="android-minSdkVersion" value="14" />
                    <preference name="StatusBarOverlaysWebView" value="false" />
                    <preference name="StatusBarBackgroundColor" value="#ee6e73" />
                    <preference name="StatusBarStyle" value="blacktranslucent" />
                    <plugin name="cordova-plugin-statusbar" source="npm" spec="~2.1.3" />
                    <plugin name="phonegap-plugin-push" source="npm" spec="~1.8.0">
                        <variable name="SENDER_ID" value="XXXXXXX" />
                    </plugin>
                    <plugin name="cordova-plugin-console" source="npm" spec="~1.0.3" />
                    <plugin name="cordova-plugin-dialogs" source="npm" spec="~1.2.1" />
                    <plugin name="cordova-plugin-whitelist" source="npm" spec="~1.2.1" />
                    <platform name="android">
                        <icon density="ldpi" src="www/res/icon/android/drawable-ldpi-icon.png" />
                        <icon density="mdpi" src="www/res/icon/android/drawable-mdpi-icon.png" />
                        <icon density="hdpi" src="www/res/icon/android/drawable-hdpi-icon.png" />
                        <icon density="xhdpi" src="www/res/icon/android/drawable-xhdpi-icon.png" />
                        <icon density="xxhdpi" src="www/res/icon/android/drawable-xxhdpi-icon.png" />
                        <icon density="xxxhdpi" src="www/res/icon/android/drawable-xxxhdpi-icon.png" />
                        <splash density="land-ldpi" src="www/res/screen/android/drawable-land-ldpi-screen.png" />
                        <splash density="land-mdpi" src="www/res/screen/android/drawable-land-mdpi-screen.png" />
                        <splash density="land-hdpi" src="www/res/screen/android/drawable-land-hdpi-screen.png" />
                        <splash density="land-xhdpi" src="www/res/screen/android/drawable-land-xhdpi-screen.png" />
                        <splash density="land-xxhdpi" src="www/res/screen/android/drawable-land-xxhdpi-screen.png" />
                        <splash density="land-xxxhdpi" src="www/res/screen/android/drawable-land-xxxhdpi-screen.png" />
                        <splash density="port-ldpi" src="www/res/screen/android/drawable-port-ldpi-screen.png" />
                        <splash density="port-mdpi" src="www/res/screen/android/drawable-port-mdpi-screen.png" />
                        <splash density="port-hdpi" src="www/res/screen/android/drawable-port-hdpi-screen.png" />
                        <splash density="port-xhdpi" src="www/res/screen/android/drawable-port-xhdpi-screen.png" />
                        <splash density="port-xxhdpi" src="www/res/screen/android/drawable-port-xxhdpi-screen.png" />
                        <splash density="port-xxxhdpi" src="www/res/screen/android/drawable-port-xxxhdpi-screen.png" />
                    </platform>
                    <platform name="ios">
                        <icon height="57" platform="ios" src="www/res/icon/ios/icon.png" width="57" />
                        <icon height="114" platform="ios" src="www/res/icon/ios/icon@2x.png" width="114" />
                        <icon height="40" platform="ios" src="www/res/icon/ios/icon-40.png" width="40" />
                        <icon height="80" platform="ios" src="www/res/icon/ios/icon-40@2x.png" width="80" />
                        <icon height="50" platform="ios" src="www/res/icon/ios/icon-50.png" width="50" />
                        <icon height="100" platform="ios" src="www/res/icon/ios/icon-50@2x.png" width="100" />
                        <icon height="60" platform="ios" src="www/res/icon/ios/icon-60.png" width="60" />
                        <icon height="120" platform="ios" src="www/res/icon/ios/icon-60@2x.png" width="120" />
                        <icon height="180" platform="ios" src="www/res/icon/ios/icon-60@3x.png" width="180" />
                        <icon height="72" platform="ios" src="www/res/icon/ios/icon-72.png" width="72" />
                        <icon height="144" platform="ios" src="www/res/icon/ios/icon-72@2x.png" width="144" />
                        <icon height="76" platform="ios" src="www/res/icon/ios/icon-76.png" width="76" />
                        <icon height="152" platform="ios" src="www/res/icon/ios/icon-76@2x.png" width="152" />
                        <icon height="29" platform="ios" src="www/res/icon/ios/icon-small.png" width="29" />
                        <icon height="58" platform="ios" src="www/res/icon/ios/icon-small@2x.png" width="58" />
                        <icon height="87" platform="ios" src="www/res/icon/ios/icon-small@3x.png" width="87" />
                        <splash height="1136" platform="ios" src="www/res/screen/ios/Default-568h@2x~iphone.png" width="640" />
                        <splash height="1334" platform="ios" src="www/res/screen/ios/Default-667h.png" width="750" />
                        <splash height="2208" platform="ios" src="www/res/screen/ios/Default-736h.png" width="1242" />
                        <splash height="1242" platform="ios" src="www/res/screen/ios/Default-Landscape-736h.png" width="2208" />
                        <splash height="1536" platform="ios" src="www/res/screen/ios/Default-Landscape@2x~ipad.png" width="2048" />
                        <splash height="768" platform="ios" src="www/res/screen/ios/Default-Landscape~ipad.png" width="1024" />
                        <splash height="2048" platform="ios" src="www/res/screen/ios/Default-Portrait@2x~ipad.png" width="1536" />
                        <splash height="1024" platform="ios" src="www/res/screen/ios/Default-Portrait~ipad.png" width="768" />
                        <splash height="960" platform="ios" src="www/res/screen/ios/Default@2x~iphone.png" width="640" />
                        <splash height="480" platform="ios" src="www/res/screen/ios/Default~iphone.png" width="320" />
                    </platform>
                    <platform name="wp8">
                        <icon height="99" platform="wp8" src="www/res/icon/wp8/ApplicationIcon.png" width="99" />
                        <icon height="159" platform="wp8" src="www/res/icon/wp8/Background.png" width="159" />
                        <splash height="1280" platform="wp8" src="www/res/screen/wp8/screen-portrait.jpg" width="768" />
                    </platform>
                    <platform name="windows">
                        <icon height="150" platform="windows" src="www/res/icon/windows/Square150x150Logo.scale-100.png" width="150" />
                        <icon height="30" platform="windows" src="www/res/icon/windows/Square30x30Logo.scale-100.png" width="30" />
                        <icon height="50" platform="windows" src="www/res/icon/windows/StoreLogo.scale-100.png" width="50" />
                        <splash height="300" platform="windows" src="www/res/screen/windows/SplashScreen.scale-100.png" width="620" />
                        <icon height="120" platform="windows" src="www/res/icon/windows/StoreLogo.scale-240.png" width="120" />
                        <icon height="44" platform="windows" src="www/res/icon/windows/Square44x44Logo.scale-100.png" width="44" />
                        <icon height="106" platform="windows" src="www/res/icon/windows/Square44x44Logo.scale-240.png" width="106" />
                        <icon height="70" platform="windows" src="www/res/icon/windows/Square70x70Logo.scale-100.png" width="70" />
                        <icon height="71" platform="windows" src="www/res/icon/windows/Square71x71Logo.scale-100.png" width="71" />
                        <icon height="170" platform="windows" src="www/res/icon/windows/Square71x71Logo.scale-240.png" width="170" />
                        <icon height="360" platform="windows" src="www/res/icon/windows/Square150x150Logo.scale-240.png" width="360" />
                        <icon height="310" platform="windows" src="www/res/icon/windows/Square310x310Logo.scale-100.png" width="310" />
                        <icon height="150" platform="windows" src="www/res/icon/windows/Wide310x150Logo.scale-100.png" width="310" />
                        <icon height="360" platform="windows" src="www/res/icon/windows/Wide310x150Logo.scale-240.png" width="744" />
                        <splash height="1920" platform="windows" src="www/res/screen/windows/SplashScreenPhone.scale-240.png" width="1152" />
                    </platform>
                    <access origin="*" />
                    <allow-intent href="http://*/*" />
                    <allow-intent href="https://*/*" />
                    <allow-intent href="tel:*" />
                    <allow-intent href="sms:*" />
                    <allow-intent href="mailto:*" />
                    <allow-intent href="geo:*" />
                        <allow-intent href="market:*" />
                    </platform>
                        <allow-intent href="itms:*" />
                        <allow-intent href="itms-apps:*" />
                    </platform>
                </widget>
                There are no errors while building this application after zipping it in www folder.
