• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Kontur um ganze Zeile – outline around whole line of text
Participant ,
Jul 06, 2017 Jul 06, 2017
Liebes Forum,
mit Absatzlinien oder -Schattierungen kann man ja prima arbeiten. Was aber, wenn ich ein Inhaltsverzeichnis mit einer Outline um jede einzelne Zeile laufen lassen möchte (Siehe Beispiel in Zeile 1 des angehängten Bilds)? Hat jemand eine Idee? Ich habe bereits an verankerte Objekte gedacht, habe jedoch zahlreiche Dokumente mit großen Inhaltsverzeichnissen vom Kunden vorliegen. Wie könnte man ID überlisten?
Besten Dank für Eure Ideen,
Ralf
ID CC 2017.1 auf MacOS 10.12.5 (Sierra)
Dear Forum,
working with paragraph options or shadings is a nice thing to to work with, but what if I need to draw an outline around each single line of text within an index (see line 1 of attached screenshot)? I considered using anchored objects, but my client gave me lots of documents with long indexes. So, if anybody comes up with a charming work-around, I'll appreciate a lot.
Thanks for your input,
Ralf
Views
887
Translate
Translate
Report
Report
Community guidelines
community guidelines
Participant , Jul 06, 2017 Jul 06, 2017
You can also create a Paragraph Style using Paragraph with Rule above or below, each with different size so you have a "box effect" but you can avoid anchored object.
I add screen shot for better understanding. I apologize for italian interface 😉
Schermata 2017-07-06 alle 17.09.28.pngSchermata 2017-07-06 alle 17.09.19.png
Votes
Translate
Translate
Mentor ,
Convert it to table.
Votes
Translate
Translate
Report
Report
Participant ,
Thanks for your idea, winterm. I think I'd prefer working with anchored objects though, since converting to table might end up in more work. But I'll give that a try also.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Convert it to table and work with cell strokes.
Converting to text to table, is pretty easy. Create table in Adobe InDesign
-Aman
Votes
Translate
Translate
Report
Report
Participant ,
thx Aman
Votes
Translate
Translate
Report
Report
Community Expert ,
Indexes are meant to be updated when the source files are edited, so we shouldn't edit the indexes because we lose those edits when we update. This is the argument to discourage your client from adding these boxes.
That said, the table option is one avenue, the other, is as you said, anchored frames. It sounds like you are already familiar with anchored frames, but let's make sure you know the quickest workflow:
  1. Draw the unassigned frame over the text.
  2. Select the frame with the Selection tool, then Alt/Opt drag the anchor box to the beginning of the first line (outlined in orange above). Press Enter/Return to close the Anchored Object Options dialog box. The frame anchors in that position to that line and will move with edits.
  3. The boxes be removed when you update your index, though.
Votes
Translate
Translate
Report
Report
Participant ,
Thx a lot, BarbBinder, thats exactly the way I used to solve this problem.
Votes
Translate
Translate
Report
Report
Participant ,
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi michelad19794771
thank you for posting your solution.
May I assist with some screenshots from a German InDesign?
I think Ralf is using a German version.
This trick using Rule Above and Rule Below works best with single line paragraphs.
And since "[Paper]" color of Rule Below is obscuring the color of Rule Above there should be no drawing objects behind the text frame.
It could take some time to get the numbers right, but I think it's worth the effort.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
LEGEND ,
In a galaxy, far far away! … where no need anchored frames or para rules tricks!
Just InDesign and ParagraphBorder!
Votes
Translate
Translate
Report
Report
Participant ,
Thx for pointing me to ParagraphBorder. May the force be with you, Obi-wan Kenobi.
Votes
Translate
Translate
Report
Report
Participant ,
Grazie, michelad19794771, very interesting solution!
Votes
Translate
Translate
Report
Report
Participant ,
Jul 07, 2017 Jul 07, 2017
LATEST
You welcome!  😉
Votes
Translate
Translate
Report
Report
Participant ,
Thank you Laubender, glad to learn from you guys. Awesome!
Votes
Translate
Translate
Report
Report
Participant ,
Thank you everybody for your helpful input. I've just set up the paragraph style with upper and lower rulers. This is indeed a very smart work-around and works charmingly well. Thanks again for sharing your knowledge. I appreciate a lot.
Best wishes, Ralf
Votes
Translate
Translate
Report
Report
