7 Replies Latest reply on Jul 7, 2017 1:01 PM by sargums46564804
    Force selection of drop down
    sargums46564804
      Is there a way to force user to make a selection from a drop down before allowing them to move on to the next field?  Like it lights up red if selection not made?  I know in TurboTax, it won't let me do anything if I don't make a choice.  I want the field box to turn red and then an asterisk to come up telling user to make a selection.
      I know how to do this by adding an app alert if the field is null but wanted to introduce a visual affect as well.
      Thx.
      Sue
        • 1. Re: Force selection of drop down
          Joel_Geraci Adobe Community Professional
          Trying to clarify...
          If the user enters the dropdown field you want them to...
          A) not be able to exit until they make a selection or
          B) you want to allow them to exit but change the appearance of the dropdown field to indicate a value is required.
          If A, you don't need B.
          If B, you don't actually want A.
          • 2. Re: Force selection of drop down
            sargums46564804 Level 1
            I guess A is the most simple so A.
            I tried the following after the user clicks the okay button but nothing happens:
            if ("ok" == cRtn)
                  if (global.docNumAction.strExmp == null) //Ensure the document type is selected
                  app.alert (("Please select document type"))
            • 3. Re: Force selection of drop down
              I even tried adding .value but it seems it won't recognize a null value.  What am I doing wrong?  I want it to generate an app alert when there is no value in the strExmp field which starts of as "" and gets populated by drop down (if selected).  I want it notice thatno value was chosen from the drop down list and to alert the user.
              if ("ok" == cRtn)
                    if (global.docNumAction.strExmp.value == null) //Ensure the document type is selected
                    app.alert (("Please select document type. This field cannot be blank"))
              • 4. Re: Force selection of drop down
                Bernd Alheit Adobe Community Professional & MVP
                What is the name of drop down field?
                • 5. Re: Force selection of drop down
                  The drop down field is named:
                  "LTyp": function(dialog)
                              var oRslt = dialog.store();
                              var path = [];
                              var cSel = ((this.GetListSel(oRslt["LTyp"],path))?path.reverse():"").toString();
                              var oLabInfo = this.oDocNumParams[cSel];
                  I just tried with LTyp == null and oLabInfo == null and no effect.
                  • 6. Re: Force selection of drop down
                    Here's more:
        type: "view",
        align_children: "align_top",
        elements:
        type: "static_text",
        item_id: "sta3",
        name: "1. Select Document Type:",
        type: "popup",
        item_id: "LTyp",
        variable_Name: "strLTyp",
        width: 93,
        height: 23,
        char_width: 8,
                    • 7. Re: Force selection of drop down
                      I am getting closer but now I am getting an app alert no matter if the drop down list has a selection or not.  I want it to only give me this error if the user has not made a selection from the drop down.  Any suggestions are welcome.
                                  var path = [];
                      if ("ok" == cRtn)
                             if(this.LTyp == null)  //Ensure the document type is selected
                            app.alert("Please select 'Document Type'. This field cannot be blank.")
                            app.execDialog(global.DocNumAction);
