1 Reply Latest reply on Jul 6, 2017 12:48 PM by Bill Silbert
    Alternating Row Fills is not Working
    michelelharry
      When I create a table and go to table options for alternating pattern, I will select every other (or any other pattern) and it defaults back to none.
      It used to work just fine, but doesn't anymore.  Indesign CC 2017 - latest upate.
      Does anyone else have this problem?
      thanks!
        • 1. Re: Alternating Row Fills is not Working
          Bill Silbert Adobe Community Professional
          Have you tried deleting your preferences?
          To do so:
          For Macintosh Users: With InDesign closed launch a Finder Window in column view and click on your home folder. With the Option Key pressed choose Library from the Finder Go Menu. Within the Library folder find the following two files and delete them: “Adobe InDesign” and “com.adobe.InDesign.plist”. When InDesign is next launched it will create new preference files and the program will be restored to its defaults.
          After you’ve reset up the program (make sure that no document window is open) to your liking, it is a really good idea to create copies of your personalized “mint” preference files (make sure that you quit the program before copying them—that finalizes your customization) and use them in the future to replace any corrupt versions you may need to delete.
          For Windows Users: Hold down Ctrl + Alt + Shift when launching InDesign and respond affirmatively when asked if you want to reset.
          2 people found this helpful
