• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Indesign document corupted
New Here ,
Jul 07, 2017 Jul 07, 2017
I am trying to open my one indesign document but upon opening it, it says indesign stoped woring and closes the program PLEASE HELP
Views
181
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jul 07, 2017 Jul 07, 2017
Can you open your back-up file? (If you don't have one, this is a great reminder of why you want to back up your active files on a separate drive.)
Sometimes simply copying the file can get rid of minor errors that are otherwise preventing you from opening your original file. Start with File > Open. Navigate to your InDesign file and click to select it. From the bottom of the Open window, choose Open Copy. InDesign will open the file as an Untitled copy.
If nothing else works, check out Markzware DTP File Recovery Service.
Votes
Translate
Translate
Community Expert ,
Try deleting your preferences.
To do so:
For Macintosh Users: With InDesign closed launch a Finder Window in column view and click on your home folder. With the Option Key pressed choose Library from the Finder Go Menu. Within the Library folder find the following two files and delete them: “Adobe InDesign” and “com.adobe.InDesign.plist”. When InDesign is next launched it will create new preference files and the program will be restored to its defaults.
After you’ve reset up the program (make sure that no document window is open) to your liking, it is a really good idea to create copies of your personalized “mint” preference files (make sure that you quit the program before copying them—that finalizes your customization) and use them in the future to replace any corrupt versions you may need to delete.
For Windows Users: Hold down Ctrl + Alt + Shift when launching InDesign and respond affirmatively when asked if you want to reset.
After you've done that try launching InDesign without opening any document. If that works create a new document and see if you can work in that and save it. If all is working up to there then try and open the original document. If you're back to the original problem then it is a problem with the document. If that document prevents the program from continuing to work repeat the steps of deleting the preference files.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
If nothing else works, check out Markzware DTP File Recovery Service. Markzware provides a DTP (Desktop Publishing) file recovery service for bad or corrupt Adobe InDesign files, and they have helped other users on this forum.
Votes
Translate
Translate
Report
Report
