Hey guys hoping you might be able to point me in the right direction here. I'm a noob at scripting Illustrator and have been racking my brain over this script for a few days now. What i would like to achieve is creating a script that will print a Postscript file to a designated folder with no user interaction. This folder will be on an external volume but just trying to get it to a folder on my desktop at this point... so this is what i started with initially :
var options = new PrintOptions();
options.printPreset="PS_print";
myDoc.print(options);
Simple, and it works except that i still have to designate the folder in which the PostScript will be saved.. so i did some digging and came across this code Muppet Mark created on a thread called " Script: print to PostScript" here Re: Script: print to PostScript . i ran it through ExtendScript and it executed once fine only thing i need to change is where the file is saving. So i edited it and came up with this:
printPostScript();
function printPostScript(){
app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
var docPath, docs, opts, psPath;
jobOpts = new PrintJobOptions();
opts = new PrintOptions();
opts.printPreset = 'PS.print';
opts.jobOptions = jobOpts;
docPath = decodeURI( app.activeDocument.fullName );
psPath = new File( "~/Desktop/TEST" );
jobOpts.file = File( psPath );
app.activeDocument.print( opts );
app.activeDocument.close( SaveOptions.DONOTSAVECHANGES );
app.userInteractionLevel = UserInteractionLevel.DISPLAYALERTS;
problem is every time i use the userinteractionLevel command illustrator throws me an error for the line where its supposed to execute the actual printing
"app.activeDocument.print( opts );" Or at least im assuming the userinteractionLevel command is the culprit as Illustrator throws me the same error with the script that i started with now when it didnt before. If any of you guys could help me out here it would be appreciated!
You assign new File() to a variable named psPath. It's nothing magic with that variable name. You could name it whatEverThatIsWhatIsStoredInMe; if you assign a file and not a folder the file is stored and not the folder.
So in effect you are storing a file in variable psPath. The name of the file is simply TEST and is saved directly on the Desktop. If you want a file in folder TEST then add a reasonable file name to the string.
"~/Desktop/TEST/myPostScriptFile.ps"
Or have a new look into the script
...Copy link to clipboard
You mention twice that you get "an" error. Don't keep us in suspense! What error do you get?
I guess it would help if gave the error huh lol sorry for the undue suspense.
It tells me an Illustrator error occurred: 20052('TN")
Then when i try and go back and run the initial code that was executing just fine before it will highlight the line
"myDoc.print(options);"
and just say the operation was cancelled. What am I doing incorrect ?
hard to tell what is provoking the error.
At least you should give the file you are writing a decent name.
Currently you are writing a file that is named "TEST" without suffix.
I tested your code using one of my print presets and it was running as expected.
Illustrator CC v 17.1.0 on OS X 10.6.8
Regards,
Uwe
Hi Uwe !
Thanks for testing the code out for me. Its nice to know the code is executing, maybe it just something w/ my personal computer we're running the same version of illustrator.
Don't pay attention to the "TEST" name that's just me being a scripting noob and trying to figure out how to write the PostScript file to the folder located on my desktop named "TEST", the file name is actually "0904USCPWU_Franky_WHT-CRD_CF_SEPS.eps".
i thought theses lines of code
got the actual file name then wrote it to that location. how should i be doing this ?
Or have a new look into the script where you copied the code from.
There a file is done by using the AI file name. But in a different line of code you did not copy over. The suffix ai is replaced by ps using a regular expression.
If you want to use the name of your active document you could do something like that where a regular expression is used to replace the .ai at the end of the name with .ps.
Here an example:
psPath = new File( "~/Desktop/TEST/"+app.activeDocument.name.replace(/\.ai$/,".ps") );
Now you are using TEST as a folder name plus the name of the active document as base name for the file.
ps stands for PostScript. Not for EPS ( Encapsulated PostScript ).
That's a difference! If you want an EPS file you have to use Illustrator's save feature.
Regards,
Uwe
//EDITED
Thanks for the assist and insight Uwe!
your explanation and example "psPath = new File( "~/Desktop/TEST/"+app.activeDocument.name.replace(/\.ai$/,".ps") ); "
made it execute perfectly.
Below is the final code if anyone is interested:
var docPath, opts, psPath;
psPath = new File( "~/Desktop/TEST/"+app.activeDocument.name.replace(/\.eps$/,".ps") );
app.activeDocument.close( SaveOptions.SAVECHANGES );
printPostScript();
