I've added a nested style to a paragraph style: one bold italic word at the beginning of the paragraph. But it never shows up as bold italic, and I have to apply the style with the character menu by hand. No style other than the paragraph style (which includes the nested style) is applied.
Here are the steps:
Unless you post screenshots of the paragraph style you have set, (which included nested style settings and the character styles defination) it is practically impossible to understand what might be causing the problem.
If you are sure everything is set correctly, you can start by reading this Drop caps and nested styles in InDesign and cleaning your cache and preferences
Troubleshooting 101: Replace, or "trash" your InDesign preferences
-Aman
The nested style is ONE word with a different style than the rest of the paragraph.
Here's a screen shot; I'm not sure if it's what you requested.
What I can't see from your screen shot:
Here are the steps:
Also, assuming you followed all the steps (and Barb's advice) and it's still not working, did you create the character style from within the Nested Styles/Paragraph Style dialog box? I'm aware of a long-standing bug when creating Character Styles from within the GREP Styles pane...where it just plain doesn't work. Try creating the char style via the char styles panel and choosing it from the nested styles dialog box.
Yes, the paragraph style is 8Note and yes I created the Bold word in the Character menu, then tried to apply it. Yes, it applies to a string of text. I've now changed the style but will try Barb's advice. Thanks.
Now that I've made the style of the single word small caps it seems to be functioning correctly.
Ok, so it's working correctly now? Do you need any other help on this?
Well, in that I gave up and changed the style, yes. I wondered if it was because the Word document styles were overriding the InDesign styles, but that wasn't it. I'll try your earlier instructions later. Thanks!
