2 Replies Latest reply on Jul 10, 2017 11:35 PM by denisc31888652
    Illustrator 2017 script for creating layers from spot colors in document
    denisc31888652
      Hello, i have script that I use in my workflow everyday but with new Illustrator 2017 I get an error.
      The script is trying to find 4 spot color in document (Cut, Crease, Reverse crease and Outside bleed) and put every single color in own layer named as follows:
      Spot color "Cut" > layer "Thru-cut"
      Spot color "Crease" > layer "Crease"
      Spot color "Outside bleed" > layer "Bleed"
      Spot color "Reverse crease" > layer "Crease"
      Script that I have used in old Illustrator is this:
      #target Illustrator
      //Apply to myDoc the active document
      //define firts caracter and how many layers do you need
      var layerIniName =65;
      var numberOfLayers=2;
      //Create the layers
      for(var i=0; i<=numberOfLayers; i++) {
      var layerName = String.fromCharCode(layerIniName)
      var myLayer = myDoc.layers.add();
      myLayer.name = layerName
      layerIniName++
      // JavaScript Document
      var doc = app.activeDocument;
      // name indexed object
      var layernames = {
      'A':'Bleed / Grafika',
      'B':'Crease',
      'C':'Thru-cut'
      // loop through all layers
      for (var i = 0; i < doc.layers.length; i++)
      //Set up Variable to access layer name
      var currentLayer = app.activeDocument.layers[i];
      if (layernames[currentLayer.name])
        currentLayer.name = layernames[currentLayer.name];
      var paths = doc.pathItems;
      var destLayer = doc.layers.getByName ("Thru-cut");
      for (var g=0; g<paths.length;g++){
          if (paths[g].strokeColor.typename == "SpotColor" && paths[g].strokeColor.spot.name == "Cut") {
              paths[g].move(destLayer, ElementPlacement.PLACEATBEGINNING);
      var destLayer = doc.layers.getByName ("Crease");
          if (paths[g].strokeColor.typename == "SpotColor" && paths[g].strokeColor.spot.name == "Crease") {
      var destLayer = doc.layers.getByName ("Bleed / Grafika");
          if (paths[g].strokeColor.typename == "SpotColor" && paths[g].strokeColor.spot.name == "Outside Bleed") {
          if (paths[g].strokeColor.typename == "SpotColor" && paths[g].strokeColor.spot.name == "Reverse crease") {
      Can anybody help me resolve this script with new Illustrator?
      Denis
      Sample file and script link:
      https://www.dropbox.com/sh/hiffbk7yd3lspjg/AACdWhCbuMf2QC3fET8dd4mta?dl=0
        • 1. Re: Illustrator 2017 script for creating layers from spot colors in document
          Loic.Aigon Adobe Community Professional
          Let's try to make things simple.
          var main = function(layerCount) {
          var doc, layers;
          if ( !app.documents.length ) {
          alert("This scripts needs an open document !");
          return;
          //The doc
          //Adding useful layers
          addLayers ( doc );
          //Moving items onto specific layers
          moveItems ( doc );
          var moveItems = function ( doc ) {
          var items = doc.pageItems, item, n = items.length, sc, tn, sn,
          layers = getLayersDB(doc),
          cutLayer = layers['Thru-cut'],
          creaseLayer = layers.Crease,
          bleedLayer = layers['Bleed / Grafika'];
          while ( n-- ) {
          item = items[n];
          sc = item.strokeColor;
          tn = sc.typename;
          if ( tn =="SpotColor" ) {
          sn = sc.spot.name;
          if ( sn=="Cut") {
          item.move(cutLayer, ElementPlacement.PLACEATBEGINNING);
          else if ( /^(Reverse )?Crease$/i.test( sn ) ){
          item.move(creaseLayer, ElementPlacement.PLACEATBEGINNING);
          else if ( sn=="Outside Bleed") {
          item.move(bleedLayer, ElementPlacement.PLACEATBEGINNING);
          var addLayers = function ( doc ) {
          var layers = getLayersDB ( doc );
          var layerNames = [
          'Bleed / Grafika',
          'Crease',
          'Thru-cut'
          name;
          while ( name = layerNames.pop() )  !layers[name]  && addLayer ( doc, name );
          var addLayer = function ( doc, name ) {
          doc.layers.add().name = name;
          var getLayersDB = function ( doc ) {
          var db = {}, layers = doc.layers, n = layers.length, layer;
          while ( n-- ) {
          layer = layers[n];
          db[layer.name] = layer;
          return db;
          main();
          HTH
