I was creating some lower thirds in AE and wanted the text to be directly editable in Premiere..
however I don't see the Export Composition as Text Template option.
Why is this ?
If you want to change the motion graphic template itself, you will need to open the aep file in Ae and export another motion graphic template. If all you need is a text change, I would stick to importing the aep file to Premiere and changing the text in the effect control. This way any change you make to the aep will reflect on all its clip instances in Premiere.
Why didn't you try Googling the problem first? Adobe have a solution here
That workflow is now replaced with the much more powerful Motion Graphics Templates. You're going to love them! Read about them here: After Effects CC (April 2017) In-Depth: Essential Graphics panel and Motion Graphics templates
Once I create a template and export it for Premiere, is there a way to edit that template again back in AE ?
