1 Reply Latest reply on May 25, 2006 6:21 AM by Bohillian
    Unable to Install Flash
    adobe_user
      I currently have IE 6.0 on XP SP2, and I am unable to download Flash from the following HTML
      http://www.adobe.com/shockwave/download/triggerpages_mmcom/flash.html
      I did not get any pop up block bar or warning and I tried manually turning off block pop-up from the privacy tab of the Internet Options dialog box.
      Any ideas?
        • 1. Re: Unable to Install Flash
          Bohillian
          This could be as a result of a couple of issues.
          1. Are you installing this from behind a firewall? If so, you will need to release the firewall restrictions on Adobe.com
          2. Is your proxy-server (assuming you are using one) set correctly?
          3. Do you have administrator rights on that computer? If not, you won't be able to download and install any software.
