• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Rendering problem
New Here ,
Jul 10, 2017 Jul 10, 2017
Hi! I have Adobe After Effects CC 2017, i made a video about 4 minutes, some motion animations in the beginning and then a simple audio spectrum.
But it takes a lot of time to render. Almost five hours.
After Effects uses my CPU because it doesn't want to use my GPU (i don't know why).
Also my laptop specs:
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_r4.141028-1500)
           Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK COMPUTER INC.
       System Model: X550EP
               BIOS: X550EP.303
          Processor: AMD A4-5100 APU with Radeon(TM) HD Graphics     (4 CPUs), ~1.5GHz
             Memory: 4096MB RAM
Available OS Memory: 3524MB RAM
          Page File: 3143MB used, 4988MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
Display Devices
          Card name: AMD Radeon HD 8330
       Manufacturer: Advanced Micro Devices, Inc.
          Chip type: AMD Radeon HD 8330 (0x9832)
           DAC type: Internal DAC(400MHz)
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_1002&DEV_9832&SUBSYS_148D1043&REV_00
     Display Memory: 3054 MB
   Dedicated Memory: 1518 MB
      Shared Memory: 1536 MB
       Current Mode: 1366 x 768 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: unknown
         Monitor Id: CMO15A7
        Native Mode: 1366 x 768(p) (59.989Hz)
        Output Type: Internal
        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1267 (English)
     Driver Version: 13.352.1013.1001
        DDI Version: 11.1
     Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
           Miracast: Not Supported by WiFi driver
Hybrid Graphics GPU: Not Supported
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 2/13/2015 16:11:38, 1329864 bytes
        WHQL Logo'd: Yes
What should i do?
Views
823
Translate
Translate
Report
Report
Community guidelines
community guidelines
People's Champ , Jul 25, 2017 Jul 25, 2017
Are still asking why it takes so long or are you just sharing your video?   If the former nobody can tell you much based on the finished product.  As well as what effects you used It also depends on your workflow, the exact specs of images you used.  Two images that are visually identical can require drastically different resources.  I might get handed a file that slows AE down to a crawl but after I convert that same image to more a efficient format, pixel density, etc... it's like it's not eve
Votes
Translate
Translate
LEGEND ,
5 hours for 4 minutes of video sounds perfectly normal. given the fact your computer specs barely qualifies for Ae's system requirements, I would say you are lucky to finish a project. As for GPU, most of Ae does not benefit from GPU acceleration. You could try to enable it for effects in the project settings if there's an option for you there. It probably won't help anyway.
What I would do with such a long composition is render a lossless version in QT Animation and then use that for encoding in AME so I can experiment with different compressed outputs without the need to render the whole thing all over again.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Perfectly normal? Not to me it doesn't, I've edited Battlefront footage and added stuff in for a 10 minute video and only ended up with an hours render time, but the time is completely dependent on what is in the video.
cristianâ„¢ what sort of animation have you done and what is the audio spectrum like? Are you rendering from AE or AME?
Votes
Translate
Translate
Report
Report
LEGEND ,
Welcome to Adobe software.  Get used to it.  Or don't use it.
Votes
Translate
Translate
Report
Report
People's Champ ,
Dave have you been eavesdropping on the marketing department again?
~Gutterfish
Votes
Translate
Translate
Report
Report
Community Expert ,
While a 1.5GHz machine might make it to the finish line, it isn't going to win any render races.
-Warren
Votes
Translate
Translate
Report
Report
New Here ,
Nexahs1138 this is the video that takes 5 hours to render Intro live for James Gaming (Audio Spectrum) #2 - YouTube
Votes
Translate
Translate
Report
Report
People's Champ ,
Are still asking why it takes so long or are you just sharing your video?   If the former nobody can tell you much based on the finished product.  As well as what effects you used It also depends on your workflow, the exact specs of images you used.  Two images that are visually identical can require drastically different resources.  I might get handed a file that slows AE down to a crawl but after I convert that same image to more a efficient format, pixel density, etc... it's like it's not even there.  And their physical size on disc can be exactly the same.
Based on your initial post it seems you do not know alot about After Effects & as others have pointed out your system specs barely meet requirements.   Without detailed information about all your assets and how you employed them I don't think anybody is going to be able to tell you why your render times are what they are or what you need to change to speed them up other than your hardware.
These types of problems are inevitable when we really don't understand the tools we're using.
Unfortunately there are not alot of learning resources I am aware of that go into great detail about render setting, codecs, formats etc...
They usually just show you what to set it at (if your lucky).
The detailed info that there is out there about these subjects is very dense (at least for me) & at times can seem like they're written in Chinese..unless you're Chinese, I suppose.
Keywords: prerendering, pre-composing, baking animation, optimizing assets, efficient workflow....
Shibumi
~Gutterfish
Votes
Translate
Translate
Report
Report
New Here ,
Gutter-Fish​ your message is not very helpful but i understand that the problem is my hardware. Nobody tells me how to make After Effects use the GPU. But it's ok. Thank you all for the support.
Votes
Translate
Translate
Report
Report
People's Champ ,
LATEST
I believe somebody already told you that AE does not use the GPU for final rendering and suggested using media encoder although i doubt that will make much difference and like I said your workflow may also be a significant part of the inefficiency.  No way to know really  I believe there may be some external rendering engines that might be able to render AE projects but I'm not sure.  Octane Renderer pops into my head but I dont know much about it.  You might want to look into it.
~Gutterfish
Votes
Translate
Translate
Report
Report
Community Expert ,
I would also recommend to use Media Encoder application. It may show you other options about rendering.
Votes
Translate
Translate
Report
Report
