0 Replies Latest reply on Jul 10, 2017 12:34 PM by luizdsilveira
    Check if objects are smaller than 1mm
      I have a very common and boring task here: check in a file full of text for all characters smaller than 1mm hight (need it before sending some package design to print due to local regulation). To make it easier I assembled the script below, but the problem is when texts are converted to outline, the script will check even the holes inside the characters, and will count them if they are smaller than 1mm.
      I've tried to maybe select a word and Pathfinder / Unit it, to make sure all holes will me merged, but didn't find a way.
      Does someone has a better idea?
      tell application "Adobe Illustrator"
        tell document 1
        set layers's visible to false
      -- Select all text and put in a new layer
      make layer with properties {name:"1_LayerTextosMenores"
        set myText to every text frame
        duplicate myText to layer "1_LayerTextosMenores"
      -- Convert those texts to Outlines.
        tell layer "1_LayerTextosMenores"
        repeat with x from (count every text frame) to 1 by -1
        tell text frame x
        convert to paths
        end try
        end tell
        end repeat
        end tell
      -- make all Stroked part of the text, to avoid it to not be counted in height
        tell application "System Events" to keystroke "a" using command down
        tell application "System Events" to keystroke "g" using command down & shift down
        click menu item "Outline Stroke" of menu "Path" of menu item "Path" of menu "Object" of menu bar item "Object" of menu bar 1 of process "Adobe Illustrator"
        end tell
        end tell
      -- create layer to put all text that it's not important to me: bigger than 1mm
        make layer with properties {name:"2_LayerTextosMaiores"}
        set Tcount to count of every path item
        repeat with i from 1 to Tcount
        set CH to the (height of path item i) / 28.3439902
        if CH > 0.1 then
        move path item i to layer "2_LayerTextosMaiores"
        end try
        end if
        end repeat
        end tell
      end tell
