1 Reply Latest reply on Jul 10, 2017 5:15 PM by BarbBinder
    Chart issues.
      How can I remove only a corner of my chart?  I need to remove 2 squares in a row and 2 squares in a column. Thank you.
        • 1. Re: Chart issues.
          BarbBinder Adobe Community Professional
          Hi Jen:
          The term chart typically refers to a bar chart or a pie chart. Are you talking about a table with rows and columns?
          Are you trying to remove the contents of those four cells, or to hide them entirely?
          • If remove contents, select the cells with the Type tool and press Delete.
          • If hide them entirely, select the four cells with the Type tool, press Delete to remove the contents, then
            • Click each of the lines in the table proxy to change all the lines to blue, except for the left and the bottom lines, which need to be gray
            • Select Stroke and set to None
