3 Replies Latest reply on Jul 12, 2017 2:12 AM by K.Daube
    Localisation problem
    K.Daube Level 2
      Friends and experts,
      On my English Win7-x64 with FrameMaker 14.0.2.425 (en) I have this very simple script, which I also tested on the machine of my wife (Win7-x32, German) with the German version of FM 14.0.2.425:
      /* ETBtest.jsx
         To be placed in Startup folder of user area */
      #target framemaker
      alert ("Testing $.locale= " + $.locale);
      var gsETBtest_title = { en: "Testing a jsx script in %apdata%\...\FrameMaker\vv\Startup [ETB]",
                              de: "Test eines jsx scripts in %apdata%\...\FrameMaker\vv\Startup[ETB]"
      var gsETBtest_msg   = { en: "Befor You test your own script, rename this script to ETBtest-ori.jsx"
                                + "\n• Name Your script ETBtest.jsx"
                                + "\n• You can now invoke it from the ETB tool-bar Extra (last icon)."
                                + "\n\nAfter your tests please rename ETBtest-ori.jsx back to ETBtest.jsx",
                              de: "Vor dem test Ihres scripts bitte dieses script auf ETBtest-ori.jsx umbenennen"
                                + "\n• Benennen Sie ihr script ETBtest.jsx"
                                + "\n• Nun kann ihr script von der ETB tool-bar Extra (letztes icon) aufgerufen werden."
                                + "\n\nNach den tests bitte ETBtest-ori.jsx zurück benennen auf ETBtest.jsx"
      var gsETBtest_NoDoc = { en: "No book or document active",
                              de: "Kein buch oder dokument aktiv"
      SetUpMenu();                                      // out-comment for debugging
      function SetUpMenu() { // =========================================================================
      // This function MUST NOT be named DefineMenu - because this is a reserved function!
      // Errors in ESTK: Menu position can not be changed - see bug report FRMAKER-2752
      // No menu is defined here - it is set up in customui.cfg / menus.cfg
        var cmdDoc = DefineCommand (1, "ETBtest", "Test a script [ETB]", "");
        UpdateMenus();
      } // --- end SetUpMenu
      function Command(cmd) { // ========================================================================
          switch(cmd)  {                                    // Respond to menu command.
              case 1:
            WhatIsToDo();
            break;
      } // --- end Command
      function WhatIsToDo () { // === This is what the test script will do ===============================
        alert (localize(gsETBtest_msg), localize(gsETBtest_title));
        return;
      On my English system/FM the alert reports
        Script Alert
        Testing $.locale= 2
      and the invoked script (by button) reports the en message from the gsETBtest_msg object.
      On the German system/FM the alert reports
        Script Fehler
        Testing $.locale= 3
      I get the German 'reaction' of the script only if I insert on the top of the script - which of course is not very useful for a bi-lingual script:
        $.locale = "de";
      What goes wrong here?
      The method is described in JavaScript Tools Guide of CS5.
      By the way: changing the order of the string declarations (have de first, en second) has no effect on both systems.
        • 1. Re: Localisation problem
          K.Daube Level 2
          Well, most likely the cause is the missing ESTK tool kit - which is not contained in TCS7. Hence I could not install it on the German system.
          Since only used for a test period I will install it from TCS6 and look further.
          • 2. Re: Localisation problem
            K.Daube Level 2
            The installation of ESTK 3.5 (which is free and not a cloud stuff) did only help in one point: in FM File > Scripts > New Script opens ESTK.
            However, the script still does not automatically adapt to the language of the application FM. So I introduce the script with this:
            $.locale = app.Language;    // 2: en; 3: de, 4: fr
            if ($.locale = 3) {
                $.locale= "de";
            or with forcing the automatic localisation by
            $.localize = true;
            The necessity of this is - however - not clear from the documentation (JavaScript Tools Guide of CS5) which states on page 104:
            The localize function always performs its translation, regardless of the setting of the $.localize
            variable. For example:
            //Only works if the $.localize=true
               b1 = w.add ("button", undefined, btnText);
            //Always works, regardless of $.localize value
               b1 = w.add ("button", undefined, localize (btnText));
            This "Regardless of the setting of the $.localize variable" is simply wrong.
            Klaus
            • 3. Re: Localisation problem
              K.Daube Level 2
              The solution with the automatic localisation is not bullet proof:
              My system is in English (Windows, FM and all apps which provide this UI language). The input language (keyboard) is de-CH) which will trigger German in the scrips. Hence I need  a longer way - a function to switch the UI language:
              function SwitchLanguage () {; // === Switch language according to application language ============
                switch (app.Language) {
                  case Constants.FV_LANG_BRITISH:
                  case Constants.FV_LANG_ENGLISH: {
                    $.locale = "en"; break;
                  case Constants.FV_LANG_CANADIAN_FRENCH:
                  case Constants.FV_LANG_FRENCH: {
                    $.locale = "fr"; break;
                  case Constants.FV_LANG_GERMAN:
                  case Constants.FV_LANG_NEW_GERMAN:
                  case Constants.FV_LANG_NEW_SWISS_GERMAN:
                  case Constants.FV_LANG_SWISS_GERMAN:    {
                    $.locale = "de"; break;
                  default: {
              } // --- end SwitchLanguage
