4 Replies Latest reply on May 26, 2006 6:04 AM by Newsgroup_User
    Printomatic problem
    Mike Crisp Level 1
      Hi
      I have 9 separate internal casts (to keep things tidy) in a diary type project I am working on.
      I have separate scripts in each of these casts to print my fields. However it keeps reading from the original Internal cast and obviously comes up with errors.
      Is there a way to make sure each separate script reads from a specific cast ?
        • 1. Re: Printomatic problem
          Level 7
          I'm not entirely sure I understand your problem, but it sounds like you have
          members named the same. If you have two members, even in different casts,
          with the same name - Director will use the first one it finds.
          Dave -
          Adobe Community Expert
          www.blurredistinction.com
          www.macromedia.com/support/forums/team_macromedia/
          • 2. Re: Printomatic problem
            Level 7
            ... unless you refer to members with syntax along the lines of:
            tMember = member("duplicated member name", "unique cast name/index")
            • 3. Re: Printomatic problem
              Mike Crisp Level 1
              Hi I figured it out, quite simple really.
              The difference is all about " " marks !
              append doc, member "L1 Coach" - works
              append doc, member L1 Coach - tries to find a field member in the original internal cast
              append doc, member 2 - finds field member 2 in the internal cast - fine if you have a single cast
              Thanks for your help anyway !
              • 4. Re: Printomatic problem
                Level 7
                Right. I just find it better to use unique names, regardless of the cast.
                Dave -
