6 Replies Latest reply on Jul 13, 2017 6:23 AM by richardh90898362
    Issue with lightroom 6 and 5DMK4 files
    richardh90898362
      Hello  i'm using lightroom for years without any problems
      With Canon 5DMK4 files lightroom developpement module is very very very slow
      im using a Mac Pro 2012 with 6 physics Core and 16GB ram and yosemite 10.10.5
      everything is fast with 5DMK2 files
      HDD is SSD
      Im using Lightroom 6 up to date 6.10.1
      Gpu acceleration is off
      it's quite horrible because it's very very long so i cannot work properly when you have to wait a couple of second to make anything
      Please help me
        • 1. Re: Issue with lightroom 6 and 5DMK4 files
          dj_paige Level 10
          Be specific. Exactly what actions in LR Develop Module are slow?
          Did this start when you began using the 5D Mark IV? Have you changed any hardware recently?
          Are you doing a lot of brushing and/or spot healing?
          How big is your monitor (in pixels)?
          • 2. Re: Issue with lightroom 6 and 5DMK4 files
            richardh90898362 Level 1
            everithing is slow in develop module
            croping , modifying light or balance of light , every simple modifications is very long
            if i switch to a folder with with 5DMK2 pictures it s running back on the track
            i am not doing brushing or healing but only simple light and croping modification
            My monitor is full hd 1920
            It s started with  this files of 5DMK4 and the only modification i have made recently is  installing Photshop CS3
            Thank you and sorry for my english  , i am in france
            • 3. Re: Issue with lightroom 6 and 5DMK4 files
              dj_paige Level 10
              I see two problems.
              One problem is that your CPU is 6 cores, and the general consensus (unfortunately) is that Lightroom runs slowly on a 6 core (or more) machine, and that the problem doesn't seem to exist if your CPU has 4 cores.
              The other problem is that the 5DMK4 photos are 36% bigger that the 5DMK2 photos, and your CPU is very old, and apparently it is not fast enough to edit these larger photos with the same speed.
              Ideally, you want to purchase a 4 core CPU that is relatively fast by today's standards.
              Another thing you can try with the 5DMK4 files is to create Smart Previews, and then use those when you are editing, this should go faster.
              • 4. Re: Issue with lightroom 6 and 5DMK4 files
                Hello
                thanks for your Help
                when i look to processors monitor they are not 100% utilisation  , never , but im waiting in front of my screen
                Buying a new computer look strange for me
                the cpu is not at full utilisation, and i dont like the Trash bin Macpro
                i cannot understand why 35 % make à so Huge différence between super fast instant and very very long to react
                I dont want to go back to pC
                is is There an optimisation scheduled by Adobe for 6 cores machines ?
                Is it possible to. Something else?
                i am going to try smart previews
                i try with the GPu but it makes no différence
                Thank you so Much
                • 5. Re: Issue with lightroom 6 and 5DMK4 files
                  dj_paige Level 10
                  GPU is irrelevant here.
                  No one knows when Adobe will fix this 4-core issue.
                  I don't have any other ideas about your problem other than what I already said, but definitely try the Smart Previews.
                  • 6. Re: Issue with lightroom 6 and 5DMK4 files
                    Hello
                    I do not see any difference
                    do i need to delete the actual previews files ?
                    thanks
