6 Replies Latest reply on Jul 23, 2017 2:36 PM by n_payne
    PSE14 dialog dropdown boxes not working correctly
    n_payne Level 1
      I have PSE 14.1 installed on Windows 10 x64 build 1703. None of the dropdown boxes in PSE dialogs work correctly. If I click on one of them to make a choice, the box darkens in colour but the dropdown list of choices does not appear. I *can* get to the choice I want by clicking on the dropdown box to make it active and then using the up/down arrow keys on the keyboard to cycle through the choices until I find the one I want, though this is an extremely inconvenient way to have to operate. Ordinary buttons in the dialogs - eg OK, Cancel, More Options, etc, work as expected.
      Dropdown boxes in other applications on the same machine (eg Lightroom) work correctly without any problem.
      Any ideas? It seems from the appearance of the dialogs in PSE - the buttons and dropdown elements don't look like the Windows standard UI elements - that Adobe have rolled their own, and done a not very good job of it.
        • 1. Re: PSE14 dialog dropdown boxes not working correctly
          n_payne Level 1
          Ok, I managed to fix this problem by deleting Photoshop settings file (start the photo editor while you have Ctrl+Alt+Shift pressed and answer "Yes" to the dialog asking if you want to delete the file).
          However, wiping out the settings file has lost me the ability to float image windows and move them to the second monitor. Now, when I have images open in the PSE editor and select Images off the Window menu, the only option I can select is Tile. All the other options (Cascade, Float in Window, Float all in Windows, Consolidate all to Tabs) are grayed out. How do I get back the option to float images in their own window, so that I can have the PSE main window on one monitor and the image in a separate window on its own monitor?
          • 2. Re: PSE14 dialog dropdown boxes not working correctly
            arshla jindal Adobe Employee
            Thanks for reaching out to us.
            Since you have reset preferences, so you need to check the following highlighted option from Preferences (Cmd/ Ctrl + K):
            Please see related article for more information : Viewing images in Photoshop Elements
            Arshla
            • 3. Re: PSE14 dialog dropdown boxes not working correctly
              n_payne Level 1
              Ok, what I have found is the following:
              1. I delete the Photoshop settings file, open an image, and the problem with dropdown choices in dialog boxes not displaying has gone away.
              2. I go into Preferences / General and tick the option to allow floating documents in expert mode. The image window is not floating, and dropdown choices in dialogs still work correctly.
              3. I float the image window, leaving it within the main PSE window. Dropdown choices in dialogs still work correctly.
              4. I drag the image window to the 2nd monitor. Dropdown choices in dialogs now cease displaying.
              5. I drag the image window back to the same monitor as the main PSE window, and dropdown choices in dialogs now again work correctly. The image window doesn't have to be within the main PSE window to fix the problem, just on the same monitor.
              So there definitely seems to be some screwup with the PSE code dealing with dropdown boxes and dual monitors. I have the main PSE window on a Dell U3011 80cm monitor running at its native resolution of 2560x1600, and display the images on an Eizo EV3237 80cm monitor running at its native resolution of 3840x2160. The video card is an nVidia Quadro K2200 running the latest nVidia 377.48 video driver.
              • 4. Re: PSE14 dialog dropdown boxes not working correctly
                n_payne Level 1
                Is there anyone with PSE15 on Windows 10 and dual monitors of different resolution who can tell me whether this same problem happens with floating image windows on a different monitor to the main PSE window? I was intending a while ago to upgrade from PSE14 to PSE15, but I'm not going to waste my money if PSE15 has the same problem as I experience with PSE14.
                • 5. Re: PSE14 dialog dropdown boxes not working correctly
                  Jeff Arola Adobe Community Professional
                  I have windows 10 pro x64 with the creators update and pse 15.
                  I should preface by saying i haven't had any problems as far as menus not readable in any adobe programs including pse 2, pse 11 and pse 15 and few new and old photoshop versions like 6, 7, cs2 and photoshop cc using single or dual monitors.
                  There has been some confirmed font bugs in the windows creators update, but why it doesn't affect all users is a bit of a mystery.
                  I hooked up two monitors of different resolutions.
                  1920 x 1200 and 1280 x 1024
                  Here's a screenshot using pse 15.
                  Maybe you should download a thirty day trial of pse 15 and see how it goes before buying it.
                  Download Photoshop Elements free trial | Adobe Photoshop Elements
                  • 6. Re: PSE14 dialog dropdown boxes not working correctly
                    n_payne Level 1
                    I downloaded and tested the PSE15 trial version, and it doesn't have the problem (not does any other app that I split between screens - eg Silkypix, Lightroom). So it would seem to be a problem in the PSE14 code.
