4 Replies Latest reply on Jul 13, 2017 6:33 PM by 務深56435747
    ColdFusion 2016 has modified the usage of CFloop tag.
    務深56435747 Level 1
      We are migrating from ColdFusion 7 to ColdFusion 2016. When I used ColdFusion Code analyzer, I got the following error message. The specification of the code is unknown. Can anyone teach me?
      CFLOOP (9)
      Solution
      Check the usage of the tag CFloop.
      E:/wwwRoot/Extension/udf/Scr_UDF.cfm ⾏ 224
      <!--And sets the acquired value-operational years in array-->
      <cfloop index="date" to="#q.YM + 1#" from="#variable.nowYM#" step="-1" >
        • 1. Re: ColdFusion 2016 has modified the usage of CFloop tag.
          haxtbh Level 4
          ColdFusion Help | cfloop
          Cant see anything wrong with the loop you posted though.
          • 2. Re: ColdFusion 2016 has modified the usage of CFloop tag.
            務深56435747 Level 1
            Thank you for your instruction.
            I will send all contents of this file. Please confirm once again.
            Thank you.
            <cfinclude template="scr_check_UDF.cfm">
            <cfinclude template="scr_menu_UDF.cfm">
            <cfinclude template="scr_grid_UDF.cfm">
            Function name: sanitizeInput
            Summary: Perform sanitization processing.
            Arguments: str: string: String to be sanitized
            Type: String: Type of sanitization
            Return value: ret: string: sanitized character string
            <cffunction name="sanitizeInput" returntype="string" access="public">
                <cfargument name="str" required="yes">
                <cfargument name="type" required="no">
                <cfset ret = arguments.str>
                <cfset argType = "">
                <cfif isDefined("arguments.type") is "True">
                    <cfset argType = arguments.type>
                </cfif>
                <cfswitch expression=argType>
                    <cfcase value="html">
                        <cfset ret = REReplaceNoCase(ret, "<[^>]*>", "", "ALL")>
                    </cfcase>
                    <cfcase value="sql">
                        <cfset ret = REReplaceNoCase(ret, ",|'", "", "ALL")>
                    </cfcase>
                    <cfdefaultcase>
                    </cfdefaultcase>
                </cfswitch>
                <cfreturn ret>
            </cffunction>
            Function name: chkUserAuth
            Summary: User authority check function
            Argument: str: string: Screen ID
            Return value: ret: boolean: true = Authorized false = No authorization
            <cffunction name="chkUserAuth" returntype="boolean" access="public">
                <cfargument name="str" type="string" required="yes">
                <cftry>
                    <cfset chkUserAtuhSql = "
                        SELECT
                            USER_ID
                        FROM
                            MA_AUTH
                        WHERE
                            USER_ID = '" & getLoginUser() & "'
                            AND SCRREP_ID = '" & str & "'
                            AND DELETE_FLG = '0'
                    <cfquery name="rs" datasource="#request.dsn#">
                        <cfoutput>#PreserveSingleQuotes(chkUserAtuhSql)#</cfoutput>
                    </cfquery>
                <cfcatch>
                    <cfreturn false>
                </cfcatch>
                </cftry>
                <cfif #rs.Recordcount# EQ 0>
                    <cfreturn false>
                <cfelse>
                    <cfreturn true>
                </cfif>
            </cffunction>
            <!--- Check CSV output permission from login ID --->
            <cffunction name="getCsvAuth" returntype="boolean" access="private">
                <cfargument name="get_gid" required="yes" type="string">
                <cfquery name="csv_auth_rs" datasource="#request.dsn#">
                    SELECT
                        CSV_OUTPUT_AUTH_FLG
                    FROM
                        MA_AUTH
                    WHERE
                        USER_ID = '#getLoginUser()#'
                    AND SCRREP_ID = '#get_gid#'
                </cfquery>
                <cfif csv_auth_rs.recordCount EQ 0>
                    <cfreturn false>
                <cfelseif csv_auth_rs.CSV_OUTPUT_AUTH_FLG eq "1">
                    <cfreturn true>
                <cfelse>
                    <cfreturn false>
                </cfif>
            </cffunction>
            Function name: getKbnList
            Summary: Acquire and return the code list of the class specified by argument from the name master
            Argument: kbn: string: category code
            : Flg_check: boolean: If TRUE, check the deletion flag
            : Str_in: string: comma separated value extraction condition
            Return value: ret: struct: result structure
            Cd: Generic type code
            Name: Generic type name 3 (Kanji abbreviation)
            <cffunction name="getKbnList" returntype="struct" access="public">
                <cfargument name="kbn" type="string" required="yes">
                <cfargument name="flg_check" type="boolean" required="no" default="true">
                <cfargument name="str_in" type="string" required="no" default="">
                <!--- Return structure structure --->
                <cfset retList = structnew()>
                <cfset structinsert(retList, "cd", ArrayNew(1), true)>
                <cfset structinsert(retList, "name", ArrayNew(1), true)>
                <!--- Set of blank lines --->
                <cfset retList.cd[1] = "">
                <cfset retList.name[1] = "">
                <!---If the argument is blank, it returns only blank lines--->
                <cfif arguments.kbn EQ "">
                    <cfreturn retList>
                </cfif>
                <cfset strCondition = "">
                <!---If an extraction condition is set, a WHERE clause is set--->
                <cfif str_in neq "">
                    <cfset strCondition = " AND A.GEN_PUR_KIND_CD IN (#str_in#)">
                </cfif>
                <!--- DDB search --->
                <cftry>
                    <!--- Search records with category code argument kbn --->
                    <cfif flg_check eq true>
                        <cfquery name="getKbn" dataSource="#request.dsn#">
                            SELECT
                                A.GEN_PUR_KIND_CD AS CD,
                                A.GEN_PUR_KIND_NM_3 AS NAME
                            FROM
                                MT_NAME A
                            WHERE
                                A.CATEGORY_CD = '#kbn#'
                            AND A.DELETE_FLG = '0'
                            #strCondition#
                        </cfquery>
                    <cfelse>
                            SELECT
                            FROM
                                MT_NAME A
                            WHERE
                                #strCondition#
                        </cfquery>
                    </cfif>
                    <cfif #getKbn.recordcount# lte 0>
                        <!--- If no record was found --->
                        <cfreturn retList>
                    </cfif>
                    <cfcatch type="database">
                        <!--- Database error --->
                        <cfreturn retList>
                    </cfcatch>
                </cftry>
                <!--- Store acquired data in array --->
                <cfset i=1>
                <cfoutput query="getKbn">
                    <cfset i=i+1>
                    <cfset retList.cd[i] = CD>
                    <cfset retList.name[i] = NAME>
                </cfoutput>
                <cfreturn retList>
            </cffunction>
            Function name: getTransYM
            Summary: Return processing year based on closing date master
            Argument: None
            Return value: ret: array: YYYYMM format processing year / month (character string)
            <cffunction name="getTransYM" returntype="array" access="public">
            <!--- Generate an array --->
            <Cfset variable.ret = arrayNew (1)>
            <!--- Get operation date --->
            <Cfset variable.nowDate = getOperationYMD ()>
            <!--- Obtain operation date --->
            <Cfset variable.nowYM = getTheMonth (variable.nowDate)>
            In the case of
            <!--- Index of Index --->
            <Cfset variable.index = 0>
            In the case of
            <Cftry>
            <!--- "Closing day master" reading --->
            <!--- Fastening day is less than current day, acquire latest closing date --->
            <cfquery name="q" datasource="#request.dsn#" maxrows="1">
                        SELECT
                            YM
                        FROM
                            MT_TIE_DAY
                        WHERE
                            DELETE_FLG = '0'
                         AND
                            TIE_YMD < '#variable.nowDate#'
                        ORDER BY
                            YM DESC
                    </cfquery>
            <!--- Data check --->
            <!--- Perform acquisition processing only when the acquired value is numeric & 6 digits --->
            <Cfif IsNumeric (# q. Y #) is true and len (# q. Y #) eq 6>
            <!--- Set acquisition value ~ operation year to array --->
            <Cfloop index = "date" to = "# q.YM + 1 #" from = "# variable.nowYM #" step = "- 1">
            In the case of
            <!--- Ignore except 1 to 12 in the last 2 digits --->
            <Cfif Right (date, 2) le 12 and Right (date, 2) ge 1>
            <!--- Set to array --->
            <cfset variable.index = variable.index + 1>
                                <cfset variable.ret[variable.index] = date>
                            </cfif>
                        </cfloop>
                    </cfif>
                        <!---If a DB exception occurs, it outputs an error in the log and returns false--->
                        <cfset variable.array = arrayNew(1)>
                        <cfset writeLog("FS0001", "SDC101.cfm", "setDistName", variable.array)>
                    </cfcatch>
                </cftry>
                <!---When none of the data is registered--->
                <cfif variable.index eq 0>
                    <!---Keep only the year of operation--->
                    <cfset variable.ret[1] = variable.nowYM>
                </cfif>
                <!---Return array type--->
                <cfreturn variable.ret>
            </cffunction>
            Function name: getScrRepName
            Summary: Obtain the screen of the argument gId · the screen of the form ID · the form name
            Argument: gId: string: screen · form ID
            Return value: ret: string: screen / form name
            If the screen can not be found return null character
            <cffunction name="getScrRepName" returntype="string" access="public">
                <cfargument name="gId" required="yes">
                <cfset var ret = "">
                <!---Exit if gid is blank--->
                <cfif arguments.gId eq "">
                    <cfreturn ret>
                </cfif>
                <cftry>
                    <cfquery name="q" datasource="#request.dsn#">
                        SELECT
                            SCRREP_NM
                        FROM
                            MA_MENU
                        WHERE
                            SCRREP_ID = '#arguments.gId#'
                    </cfquery>
                    <cfcatch>
                        <cfreturn ret>
                    </cfcatch>
                </cftry>
                <cfif q.recordcount eq 1>
                    <cfset ret = q.SCRREP_NM>
                </cfif>
                <cfreturn ret>
            </cffunction>
            Function name: getLoginUser
            Summary: Retrieve the user ID of the currently logged-in user from the session variable
            Argument: None
            Return value: User ID
            <cffunction name="getLoginUser" returntype="string" access="public" output="no">
                <cfset var user_id = trim(session.user_id)>
                <cfreturn user_id>
            </cffunction>
            • 3. Re: ColdFusion 2016 has modified the usage of CFloop tag.
              BKBK Adobe Community Professional & MVP
              You should replace the HTML comment with a ColdFusion comment:
              <!--- And sets the acquired value-operational years in array --->
              • 4. Re: ColdFusion 2016 has modified the usage of CFloop tag.
                務深56435747 Level 1
                Dear Mr.BKBK
                Thank you for your solution.
                I check the ColdFusion comment.
                Thank you.
