2 Replies Latest reply on Jul 13, 2017 2:24 PM by Laurence MacNeill
    SQL server port encryption
    userCold9 Level 1
      Running Cold Fusion 11, 32 bit environment, SQL Server 2008.
      The SQL Server port 1433 has a cert installed due to the data.
      When accessing the SQL database from the Cold Fusion application, receiving the message:
      The SQL Server login requires an SSL connection.
      Prior to the cert install, could access the database.
      Is there anything in the Cold Fusion administrator that can be set?
      If not, what would be the specific instructions?
      Is there a specific version of Java that should be installed?
      Thanks for your help,
      Mike
