1 Reply Latest reply on Jul 13, 2017 1:30 AM by Mike_Abbott
    Position Graphics around ellipse
      I have some graphics, in this case layers of individual fruits and I want to position it precisely around a ellipse to make like a rotation of fruits around the center of the ellipse. How can I do that? Please help!
        • 1. Re: Position Graphics around ellipse
          Mike_Abbott Adobe Community Professional
          This is actually a little bit tricky to do manually, so I've written you an expression...
          1. set up a null - rename it "center"
          2. Put your first fruit layer directly underneath the null layer. On that first fruit layer put this expression onto the position property:
          majorA = 600;
          minorA = 300;
          LrTot = 8;
          nullPos = thisComp.layer("center").position;
          nullRot = thisComp.layer("center").rotation;
          LrNum = index-2;
          angle = degreesToRadians((360/LrTot*LrNum)+nullRot);
          nullPos+[x, y]
          You will need to change the numbers on the first three lines:
          majorA = the width of your ellipse
          minorA = the height of your ellipse
          LrTotal = the total number of layers to be distributed around your ellipse
          Highlight the position property on that layer. Go to the Edit menu > Copy expression only.
          Put your other fruit layers directly under the first one. Select your other layers. Edit > Paste.
          To animate the rotation -
          Animate the rotation value of the 'center' null.
