4 Replies Latest reply on Jul 12, 2017 10:06 AM by Roei Tzoref
    Inexplicably mis-aligned photoshop layers
      I have a rather odd problem with After Effects that I haven't found a solution for, so hopefully someone here can help me out.
      I have created a 2D animated short film about half a year ago using photoshop layers as frames with the outlines, colour, shading etc. as separate layers on top of each other, all imported into and subsequently animated in After Effects without any problems.
      Today upon opening the project file again for the first time since I see that all the individual layers in all compositions are now completely misaligned with each other in a rather chaotic manner. For some strange reason only background and outline layers seem completely unaffected by this.
      I have changed neither the AE-file nor the Photoshop files since I've completed the film.
      Here are screenshots of one shot- what it looks like now and what it looked like half a year ago
      Here's a frame of character animation, same problem.
      Mind you, the solid white character background doesn't stay consistently shifted to the left, it keeps jumping in all four directions in the following frames.
        • 1. Re: Inexplicably mis-aligned photoshop layers
          Roei Tzoref Adobe Community Professional
          try to isolate your problem. one composition, one Psd. see where it started to break. any plugins used in the previous project? is Ae the same version you worked on last time? if not, try opening in the same version
          • 2. Re: Inexplicably mis-aligned photoshop layers
            ottogramm Level 1
            I'm currently reinstalling the AE version I used earlier this year and see if that helps. I'm using After Effects CC vanilla, no plugins beyond that. I have tried to trace where the problem started to occur but so far all compositions and psd files from that "session" are affected. Originally I thought the file was somehow corrupted with the above curious results but the backup files behave in the same way.
            For unknown reasons slightly older AE files still work flawlessly.
            edit: ok, the older AE version did the trick. Still a rather strange effect but at least I don't have to redo 3 months of animation now.
            • 3. Re: Inexplicably mis-aligned photoshop layers
              Mike_Abbott Adobe Community Professional
              Just out of interest : what was the 'old' Ae version number - where the file is OK, and what version were you using when it was offset?
              • 4. Re: Inexplicably mis-aligned photoshop layers
                glad you got it to work, but it would help to know if there is a bug that you experienced in the new version. this information is valuable for any user that could trigger it but more importantly, the Ae Team needs to know in order to fix it.  as Mike said:
                1. what version did not work, what version did work
                2. can you provide a reduced sample project for us to dissect?
