8 Replies Latest reply on Jul 13, 2017 3:56 AM by runewold
    3D  Screencard problem with Nvidia P6000 cards
    runewold
      Hi all
      I just got a new workstation at work. Filled it with the latest hardware like the Nvidia P6000 cards.
      So it was surprising to me that Photoshop gave me error when I wanted to do a 3D extrusion.
      I have tried about everything you normally do from updates to drivers and software.
      Im on Windows 10 using the latest Photoshop on the Cloud.
      Hope to get some solving feedback :-)
      R.
        • 1. Re: 3D  Screencard problem with Nvidia P6000 cards
          davescm Adobe Community Professional
          Wow - that is some machine. I don't think you are going to get knocked down by other users comparing similar specs.
          However it will be worth pasting your system info (Photoshop - Help - System Info  click on copy button and paste into forum post) to see if anyone can spot an issue in that data.
          Dave
          • 2. Re: 3D  Screencard problem with Nvidia P6000 cards
            runewold Level 1
            Hi.
            Thank you. It was A LOT of info but im sure you knew that :-()
            Rune
            Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
            Number of Launches: 4
            Version: 10 or greater
            System architecture: Intel CPU Family:6, Model:15, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
            Physical processor count: 24
            Logical processor count: 48
            Processor speed: 2295 MHz
            Built-in memory: 130994 MB
            Free memory: 2 MB
            Memory available to Photoshop: 119553 MB
            Memory used by Photoshop: 73 %
            History Thumbnails: Enabled.
            Touch Bar: Enabled.
            Alias Layers: Disabled.
            Modifier Palette: Enabled.
            Highbeam: Enabled.
            Image tile size: 1024K
            Image cache levels: 4
            Font Preview: Medium
            TextComposer: Latin
            Display: 1
            Display Bounds: top=0, left=0, bottom=1440, right=3440
            Display: 2
            Display Bounds: top=0, left=3440, bottom=1440, right=6880
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGLGPUs=1
            NumCLGPUs=2
            NumNativeGPUs=0
            glgpu[0].GLVersion="4.1"
            glgpu[0].IsIntegratedGLGPU=0
            glgpu[0].GLMemoryMB=24576
            glgpu[0].GLName="NVIDIA Quadro P6000"
            glgpu[0].GLVendor="NVIDIA Corporation"
            glgpu[0].GLVendorID=4318
            glgpu[0].GLDriverVersion="21.21.13.7748"
            glgpu[0].GLRectTextureSize=32768
            glgpu[0].GLRenderer="Quadro P6000/PCIe/SSE2"
            glgpu[0].GLRendererID=6960
            glgpu[0].HasGLNPOTSupport=1
            glgpu[0].GLDriver="C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_eb081ce825831c2d\nvd3dumx,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_eb081ce825831c2d\nvwgf2umx,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_eb081ce825831c2d\nvwgf2umx,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_eb081ce825831c2d\nvwgf2umx,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_eb081ce825831c2d\nvd3dum,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_eb081ce825831c2d\nvwgf2um,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_eb081ce825831c2d\nvwgf2um,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_eb081ce825831c2d\nvwgf2um"
            glgpu[0].GLDriverDate="20170608000000.000000-000"
            glgpu[0].CanCompileProgramGLSL=1
            glgpu[0].GLFrameBufferOK=1
            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[0].CLPlatformVersion="1.2"
            clgpu[0].CLDeviceVersion="1.2 CUDA"
            clgpu[0].IsIntegratedCLGPU=0
            clgpu[0].CLMemoryMB=24576
            clgpu[0].CLName="Quadro P6000"
            clgpu[0].CLVendor="NVIDIA Corporation"
            clgpu[0].CLVendorID=4318
            clgpu[0].CLDriverVersion="377.48"
            clgpu[0].CLBandwidth=3.67818e+11
            clgpu[0].CLCompute=5073.15
            clgpu[1].CLPlatformVersion="1.2"
            clgpu[1].CLDeviceVersion="1.2 CUDA"
            clgpu[1].IsIntegratedCLGPU=0
            clgpu[1].CLMemoryMB=24576
            clgpu[1].CLName="Quadro P6000"
            clgpu[1].CLVendor="NVIDIA Corporation"
            clgpu[1].CLVendorID=4318
            clgpu[1].CLDriverVersion="377.48"
            clgpu[1].CLBandwidth=3.63043e+11
            clgpu[1].CLCompute=5073.05
            License Type: Subscription
            Serial number: 90960495800123010585
            GUIDBucket:
              bucket: 96
              test: ReduceUXFriction
            Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
            Temporary file path: C:\Users\Rune\AppData\Local\Temp\
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Startup, 952,9G, 741,3G free
            Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
            Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
            Installed components:
               A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
               ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
               AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
               AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
               AdobeOwl.dll   Adobe Owl   5.2.11
               AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
               AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
               AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
               AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
               AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
               AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
               adobe_caps.dll   Adobe CAPS   10,0,0,6
               AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
               ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
               AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
               amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
               ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
               AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
               AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
               Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
               BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
               boost_date_time.dll   photoshopdva   10.0.0
               boost_signals.dll   photoshopdva   10.0.0
               boost_system.dll   photoshopdva   10.0.0
               boost_threads.dll   photoshopdva   10.0.0
               cg.dll   NVIDIA Cg Runtime   3.0.00007
               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
               CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
               CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
               dnssd.dll   Bonjour   3,0,0,2
               dvaaudiodevice.dll   photoshopdva   10.0.0
               dvacore.dll   photoshopdva   10.0.0
               dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
               dvamarshal.dll   photoshopdva   10.0.0
               dvamediatypes.dll   photoshopdva   10.0.0
               dvametadata.dll   photoshopdva   10.0.0
               dvametadataapi.dll   photoshopdva   10.0.0
               dvametadataui.dll   photoshopdva   10.0.0
               dvaplayer.dll   photoshopdva   10.0.0
               dvatransport.dll   photoshopdva   10.0.0
               dvaui.dll   photoshopdva   10.0.0
               dvaunittesting.dll   photoshopdva   10.0.0
               dynamiclink.dll   photoshopdva   10.0.0
               ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
               icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               igestep30.dll   IGES Reader   9.3.0.113
               imslib.dll   IMSLib DLL   10.0.0.11
               JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
               libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
               libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
               LogSession.dll   LogSession   7.4.1.60.45263
               mediacoreif.dll   photoshopdva   10.0.0
               MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
               pdfsettings.dll   Adobe PDFSettings   1.04
               Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
               Plugin.dll   Adobe Photoshop CC 2017   18.1.1
               PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
               PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
               PSArt.dll   Adobe Photoshop CC 2017   18.1.1
               PSViews.dll   Adobe Photoshop CC 2017   18.1.1
               SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
               SVGRE.dll   SVGRE   79.579975   79.579975
               svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
               tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
               TfFontMgr.dll   FontMgr   9.3.0.113
               TfKernel.dll   Kernel   9.3.0.113
               TFKGEOM.dll   Kernel Geom   9.3.0.113
               TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
               updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
               VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
               VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
               WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
               wu3d.dll   U3D Writer   9.3.0.113
            Required plug-ins:
               3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Accented Edges 18.1.1 - from the file “Filter Gallery”
               Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle”
               Angled Strokes 18.1.1 - from the file “Filter Gallery”
               Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average”
               Bas Relief 18.1.1 - from the file “Filter Gallery”
               BMP 18.1.1 - from the file “Standard MultiPlugin”
               Camera Raw 9.10.1 - from the file “Camera Raw”
               Camera Raw Filter 9.10.1 - from the file “Camera Raw”
               Chalk && Charcoal 18.1.1 - from the file “Filter Gallery”
               Chrome 18.1.1 - from the file “Filter Gallery”
               Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon”
               Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
               Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Color Halftone 18.1.1 - from the file “Standard MultiPlugin”
               Colored Pencil 18.1.1 - from the file “Filter Gallery”
               CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin”
               Conté Crayon 18.1.1 - from the file “Filter Gallery”
               Craquelure 18.1.1 - from the file “Filter Gallery”
               Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto”
               Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin”
               Crosshatch 18.1.1 - from the file “Filter Gallery”
               Crystallize 18.1.1 - from the file “Standard MultiPlugin”
               Cutout 18.1.1 - from the file “Filter Gallery”
               Dark Strokes 18.1.1 - from the file “Filter Gallery”
               De-Interlace 18.1.1 - from the file “Standard MultiPlugin”
               Dicom 18.1.1 - from the file “Dicom”
               Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
               Diffuse Glow 18.1.1 - from the file “Filter Gallery”
               Displace 18.1.1 - from the file “Standard MultiPlugin”
               Dry Brush 18.1.1 - from the file “Filter Gallery”
               Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire”
               Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
               Extrude 18.1.1 - from the file “Standard MultiPlugin”
               FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore”
               Fibers 18.1.1 - from the file “Standard MultiPlugin”
               Film Grain 18.1.1 - from the file “Filter Gallery”
               Filter Gallery 18.1.1 - from the file “Filter Gallery”
               Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Fresco 18.1.1 - from the file “Filter Gallery”
               Glass 18.1.1 - from the file “Filter Gallery”
               Glowing Edges 18.1.1 - from the file “Filter Gallery”
               Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Graphic Pen 18.1.1 - from the file “Filter Gallery”
               Halftone Pattern 18.1.1 - from the file “Filter Gallery”
               HDRMergeUI 18.1.1 - from the file “HDRMergeUI”
               HSB/HSL 18.1.1 - from the file “Standard MultiPlugin”
               IFF Format 18.1.1 - from the file “Standard MultiPlugin”
               IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Ink Outlines 18.1.1 - from the file “Filter Gallery”
               JPEG 2000 18.1.1 - from the file “JPEG2000”
               Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Lens Blur 18.1.1 - from the file “Lens Blur”
               Lens Correction 18.1.1 - from the file “Lens Correction”
               Lens Flare 18.1.1 - from the file “Standard MultiPlugin”
               Liquify 18.1.1 - from the file “Liquify”
               Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
               Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
               Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Mezzotint 18.1.1 - from the file “Standard MultiPlugin”
               Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore”
               Mosaic Tiles 18.1.1 - from the file “Filter Gallery”
               Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support”
               Neon Glow 18.1.1 - from the file “Filter Gallery”
               Note Paper 18.1.1 - from the file “Filter Gallery”
               NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors”
               Ocean Ripple 18.1.1 - from the file “Filter Gallery”
               OpenEXR 18.1.1 - from the file “Standard MultiPlugin”
               Paint Daubs 18.1.1 - from the file “Filter Gallery”
               Palette Knife 18.1.1 - from the file “Filter Gallery”
               Patchwork 18.1.1 - from the file “Filter Gallery”
               Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin”
               PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX”
               Photocopy 18.1.1 - from the file “Filter Gallery”
               Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine”
               Photoshop Touch 14.0 - from the file “PSDX”
               Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
               Pinch 18.1.1 - from the file “Standard MultiPlugin”
               Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar”
               Plaster 18.1.1 - from the file “Filter Gallery”
               Plastic Wrap 18.1.1 - from the file “Filter Gallery”
               PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               PNG 18.1.1 - from the file “Standard MultiPlugin”
               Pointillize 18.1.1 - from the file “Standard MultiPlugin”
               Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin”
               Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM”
               Poster Edges 18.1.1 - from the file “Filter Gallery”
               PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Radial Blur 18.1.1 - from the file “Standard MultiPlugin”
               Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance”
               Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
               Reticulation 18.1.1 - from the file “Filter Gallery”
               Ripple 18.1.1 - from the file “Standard MultiPlugin”
               Rough Pastels 18.1.1 - from the file “Filter Gallery”
               Save for Web 18.1.1 - from the file “Save for Web”
               ScriptingSupport 18.1.1 - from the file “ScriptingSupport”
               Shake Reduction 18.1.1 - from the file “Shake Reduction”
               Shear 18.1.1 - from the file “Standard MultiPlugin”
               Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Smart Blur 18.1.1 - from the file “Standard MultiPlugin”
               Smudge Stick 18.1.1 - from the file “Filter Gallery”
               Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize”
               Spaces 18.1.1 - from the file “Spaces”
               Spatter 18.1.1 - from the file “Filter Gallery”
               Spherize 18.1.1 - from the file “Standard MultiPlugin”
               Sponge 18.1.1 - from the file “Filter Gallery”
               Sprayed Strokes 18.1.1 - from the file “Filter Gallery”
               Stained Glass 18.1.1 - from the file “Filter Gallery”
               Stamp 18.1.1 - from the file “Filter Gallery”
               Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Sumi-e 18.1.1 - from the file “Filter Gallery”
               Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Targa 18.1.1 - from the file “Standard MultiPlugin”
               Texturizer 18.1.1 - from the file “Filter Gallery”
               Tiles 18.1.1 - from the file “Standard MultiPlugin”
               Torn Edges 18.1.1 - from the file “Filter Gallery”
               Twirl 18.1.1 - from the file “Standard MultiPlugin”
               U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Underpainting 18.1.1 - from the file “Filter Gallery”
               Vanishing Point 18.1.1 - from the file “VanishingPoint”
               Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
               Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               Water Paper 18.1.1 - from the file “Filter Gallery”
               Watercolor 18.1.1 - from the file “Filter Gallery”
               Wave 18.1.1 - from the file “Standard MultiPlugin”
               Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
               WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport”
               Wind 18.1.1 - from the file “Standard MultiPlugin”
               Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP”
               ZigZag 18.1.1 - from the file “Standard MultiPlugin”
            Optional and third party plug-ins: NONE
            Duplicate and Disabled plug-ins: NONE
            Plug-ins that failed to load: NONE
            Extensions:
               Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
               com.adobe.inapp.purchase  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
               New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
               Libraries  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
               Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
               com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
               Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
               Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
               Device Preview  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
               com.adobe.preview.loader  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
            Installed TWAIN devices: NONE
            • 3. Re: 3D  Screencard problem with Nvidia P6000 cards
              The only think that sticks out as unusual to me is the NumCLGPUs = 2.  Do you have more than one card installed? Normally when we see more than one GPU it is where multiple cards are installed which is known to cause issues for Photoshop.
              Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
              If not that might be normal for that card and it would be great if someone else with a high spec Quadro can comment.
              Hopefully someone with more knowledge of this GPU will chip in here.
              Dave
              • 4. Re: 3D  Screencard problem with Nvidia P6000 cards
                runewold Level 1
                Hi
                Yes I have 2 x P6000 cards. Im at home now but will look at your suggestion in the morning. Thank you!!
                Rune
                • 5. Re: 3D  Screencard problem with Nvidia P6000 cards
                  Trevor.Dennis Adobe Community Professional
                  Yes. Like Dave says.  Photoshop is known to not like more than one GPU.  Photoshop is also lightly threaded, and relies more on CPU clock speed than lots of cores and threads.   I dread to think what your system must have cost!  $20K or more I suspect.
                  • 6. Re: 3D  Screencard problem with Nvidia P6000 cards
                    tmyusuf74 Level 3
                    Do you have an extronal graphic card if the answer is not please bought a Nvidia graphic card then open software?
                    • 7. Re: 3D  Screencard problem with Nvidia P6000 cards
                      runewold Level 1
                      Hi
                      Its a bit more for the machine :-)
                      What a strange ting. Been using Photoshop for about 25 years and never had a problem with a graphic card even when they were almost nonexistence. So to open the version that so clearly states 2017 and all that should come with that don't work with a system that is built for one purpose. To work with Adobe cloud (mostly After effects).
                      I have the new MacBook Pro and opened the file there and even on the last (2013 generation) Macbook Pro and both made extrusion in a second. Im on a set right now but will go back to the office later today and will look into what Dave suggested but if anyone has anything other ideas please share.
                      I assume im not the only one that has or will have this problem as more will take similar systems in use.
                      Thanks for taking the time Trevor
                      R.
                      • 8. Re: 3D  Screencard problem with Nvidia P6000 cards
                        runewold Level 1
                        Hi.
                        Im really sorry but im not sure if I understand your question.
                        Are you asking if I have a graphic card?
                        If that is what you are asking for I have 2 x Nvidia P6000 cards.
                        Rune
