2 Replies Latest reply on May 26, 2006 6:13 AM by CraigCC
    Delete TOC from HTML Help
    DeeHale
      Does anyone know how to prevent the TOC from appearing in HTML Help?
      I thought there is a way, but I can't seem to recall.
      Thanks!
        • 1. Re: Delete TOC from HTML Help
          Hi DeeHale
          Umm, I need to ask a really silly question here. If you click the TOC composer tab, are there entries inside? If so, deleting all the entries should cause the TOC not to be included when you compile.
          Now if you have entries you want to keep, but still delete the TOC, you can simply sneak behind RoboHelp HTML's back and rename the ProjectName.HHC file. Then it shouldn't be found and won't be included.
          Cheers... Rick
          • 2. Re: Delete TOC from HTML Help
            CraigCC Level 2
            Hi DeeHale,
            While Rick and I try and pick your brains. Another thought, are you per chance trying to call the help file from the application but would prefer the help to initially appear without the TOC/Index/Search? If so:
            1. Go to the windows folder.
            2. Right click on the primary window and select Properties from the shortcut menu.
            3. This should open up the Windows Properties HTML HTML Help window.
            4. Under tri-pane Options, check Hide Nav Pane on Startup.
            Now when the help opens up, the Contents/Index and Search will be hidden.
            Kind Regards
            Craig
