4 Replies Latest reply on Aug 1, 2017 5:10 PM by Kevin-Monahan
    Brighten Existing lighting in a scene?
    thomasp4
      I am relatively new to After Effects (CS 2017., v14.2).  I am working on a scene that I am converting to a night scene.  I know how to modify the scene to look as if it had been taken in the dark, however existing lighting (ie, Automobile lightening darkens) darkens also.   Does anyone have a video (or list of steps) showing how I can brighten existing lighting in a scene.
      Thanks.
        • 1. Re: Brighten Existing lighting in a scene?
          If your camera (or the existing lighting) is moving, you will need to get into the wonderful world of motion tracking! You'll want to track masks/shapes that reveal the original lighting (or newly created lighting). This could possibly end up being many, many layers.
          I once did a day-for-night shot that was a "superhero" on a motorcycle zooming through a college campus "quad" area. This included our stunt driver roaring under/through a clock tower at 80 mph. Super-fun to shoot, by the way.
          Anyway, I had to make the two clock faces that we could see in the shot be lit up, the motorcycle headlight, all of the walkway lights (each one was three different kinds of light, the light/lens flare at the lamp's bulb itself, the cone of hazy light it cast downward, and the lighting on the ground), office/classroom windows in the building behind, and aesthetic lights on the sides of buildings. IIRC, it was over a hundred layers all motion tracked to either the camera's movement or the motorcycle. Fun stuff.
          (Edit: I forgot to add, we were changing the beautiful yellow of the Triumph that the stunt guy was driving into a red color so that it would match our superhero's color scheme, so I had to track all of those layers/masks too!)
          It was a really cool shot and then the editor basically destroyed all of my work by cutting the shot to strobe with the beat of the music so you could barely see it! (This was back on AE version 7, by the way. Before CS5 or any of the CC versions on an old Pentium 4 machine, if I recall correctly.)
          • 2. Re: Brighten Existing lighting in a scene?
            thomasp4 Level 1
            Thanks for the response!
            Could I simply duplicate the layer, brighten the bottom layer, then use the
            pin tool to delete the lighted areas from the top layer to reveal the
            brighter lighting from the bottom later?
            If that's possible, how can this be accomplished?
            • 3. Re: Brighten Existing lighting in a scene?
              Pen tool? Yes. Mask tracking would probably be useful here if things are moving.
              It is hard to give advice without seeing the specific shot. Most shots require several different techniques. You can read up on some motion tracking techniques here.
              I think this tutorial gives some advice on day for night work.
              • 4. Re: Brighten Existing lighting in a scene?
                Kevin-Monahan Adobe Employee
                Hi thomasp,
                Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
                Kevin
