• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Pause action, move layer and continue [2017]
Community Beginner ,
Jul 13, 2017 Jul 13, 2017
I want to make an action that stops, allows me to move a layer, and then continue.  Doing a stop will not work and I can't check the box next to the action item.  Whca can I do?
TOPICS
macOS , Windows
Views
2.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jul 13, 2017 Jul 13, 2017
I have years of experance creating and editint action. What you write is not correct. You can also make an interactive steps where you the user has control  to perform a transform.
Crafting Actions Package UPDATED Aug 10, 2014 Added Conditional Action steps to Action Palette Tips.
Contains
Votes
Translate
Translate
Adobe
Community Expert ,
A stop message should work.  There is no box you want to check.  You want the action to stop so you can move the layer. You move the layer then click Play ant the action continue.  That the way stop works. The action stops in the stop step.  You do what you want to do then click Play and the action continues from the step after the stop step.
JJMack
Votes
Translate
Translate
Report
Report
That won't work but I did find a workaround. The problem is you can't do anything with moving a layer when the action is paused. The workaround is do a control t or free transform on the layer. Then you can do a pause and move as needed when you complete the transformation including the move it works fine
Bill Tucker
Tucker Creative Photo
[phone removed]
Votes
Translate
Translate
Report
Report
Community Expert ,
Contains
Example
Download
JJMack
Votes
Translate
Translate
Report
Report
New Here ,
Oct 29, 2018 Oct 29, 2018
JJMack​ - Ok, it is possible.  Sounds good.  Now can you tell us how to do that?
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 30, 2018 Oct 30, 2018
You can turn on steps dialog  to make a step interactive by checking the steps dialog box you want to make interactive or you add stop messages so the action will stop so you can do steps not in the action then you click play to continue the action.  You can make more than one step interactive and you can have more than one stop message steps.  The is also a stop with continue step where you have an option to stop the action or just continue its play.
JJMack
Votes
Translate
Translate
Report
Report
New Here ,
Aug 17, 2023 Aug 17, 2023
This is still an issue - BIG PROBLEM - and what's labeled as a "correct answer" is absolutely unhelpful. PLEASE someone answer this!
Votes
Translate
Translate
Report
Report
Community Expert ,
quote
By @paul3.14159
There are 2 options:
(A) One either inserts a stop. Then the user does something. Then they play the action from the stop point...
or
(B) Or one turns on the modal control for an interactive transform step.
Here I move the layer 1 pixel right, without the step modal control being active (this is a means to an end). This step is optional, it is really only there to illustrate the modal control being off, as opposed to on. If one is going to move or otherwise transform the layer, starting off with a 1 pixel move isn't a big deal.
Next, I move it 1 pixel left (so that they layer is back where it started) – with the modal control active to provide an interactive "pause". In effect the action is paused until the transform is completed, then the action will automatically continue playing until it hits another interactive modal,  stop step or the end of the action.
EDIT: I created a "null transform" action to start with a 0 position transform in case somebody finds it useful:
https://www.dropbox.com/scl/fi/0v2bhbyhmec4519cyxtx8/Null-Transform.atn?rlkey=y6fz4qz78lxka4k2nc06ej...
Votes
Translate
Translate
Report
Report
Explorer ,
Dec 15, 2023 Dec 15, 2023
How does one "turn on a modal control"? I'm trying to move an anchor point during my action to copy rotate a shape, but as soon as I hit enter, the anchor point goes back to the location where it was when I recorded the action.
Votes
Translate
Translate
Report
Report
Community Expert ,
The modal control is shown in the screenshot before your post, boxed in red.
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks. I did try putting one of those in, but still can't record a move of the anchor point while in Ctrl-T in an action. As soon as I close Ctrl-T, the anchor point returns to its previous location.
Votes
Translate
Translate
Report
Report
Community Expert ,
Modal controls only add interactivity, the recorded parameters are used unless changed.
Votes
Translate
Translate
Report
Report
Community Expert ,
Not sure what are you refering to, what you mean by: "As soon as I close Ctrl-T, the anchor point returns to its previous location. "
You do not close Free Transform but rather confirm to keep changes. Can you post some screenshot or short video to explain what is actual problem on your side.
Votes
Translate
Translate
Report
Report
Community Expert ,
Dec 16, 2023 Dec 16, 2023
quote
That does not actually depend on the quality of the post alone, does it?
Please provide a meaningful description (with screenshots including all pertinent Panels) of what exactly you are trying to achieve and what fails to function.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
quote
By @paul3.14159
If the answer that was correct in 2017 for this thread does not work for you, then please start a new thread and explain your issue so we can better assist. First go to the Photoshop forum using the breadcrumb at the top left, then click the blue Post button.
Jane
Votes
Translate
Translate
Report
Report
