6 Replies Latest reply on Oct 29, 2017 5:37 PM by Dov Isaacs
    Problems in Windows 10 Creators Update with Fonts Installed via “Shortcut”!
    Dov Isaacs Adobe Employee
      We have recently become aware of an anomaly that was introduced with the Windows 10 Creators Update affecting fonts that are installed via “shortcut.”
      Most fonts are either installed by the operating system or applications directly into the C:\Windows\Fonts directory and users can install fonts into that directory by right-clicking on a font and selecting “Install.” However, Windows also offers the option to install a font but keeping the font file itself in some other location in the file system. This option is invoked by right-clicking on the font file and selecting the “Install as Shortcut” option. (Many of us use such “Shortcut” installation of fonts as a means of disciplined housekeeping for large numbers of fonts and font families!)
      The anomaly is that after powering up / rebooting your system, fonts installed via “Shortcut” won't appear either in the Fonts Control Panel or in applications' font lists.
      By simply rebooting your system, those installed by “Shortcut” fonts will reappear in the Fonts Control Panel and the applications' font lists. Thus, if you have any such installed by “Shortcut" fonts, you will always need to do a second boot of your computer system until Microsoft fixes this nasty bug. Alternatively, you can uninstall those particular fonts and reinstall them via the normal “Install” which places the font files themselves in the C:\Windows\Fonts directory.
      Important Note — This anomaly does NOT appear to affect Typekit font synchronization in any way!
      Microsoft is aware of the problem, but we have no ETA for a fix. (The July 11 Windows 10 update does not fix the problem!)
              - Dov Isaacs, Principal Scientist, Adobe Systems Incorporated
        • 2. Re: Problems in Windows 10 Creators Update with Fonts Installed via “Shortcut”!
          Update on the Windows 10 Creators Update Linked Font Bug
          On behalf of Adobe and its customers, I officially submitted a bug report to Microsoft with regards to this serious problem.
          Working closely with one of their Senior Escalation Engineers in their Windows Support organization, Microsoft was readily able to reproduce the problem exactly as I represented it to them.
          Good News – Microsoft now acknowledges that this is a bug and that it will be fixed. Apparently the bug was introduced as part of major changes associated with improved security in the boot process.
          Bad News – The permanent fix for the bug will appear in the Windows 10 Creators Fall Update, the exact release date TBD. This fix isn't something that is readily exportable as a patch in one of the upcoming monthly updates.
          Good News – There is a very reliable workaround, based on a single registry entry, which forces rebuild of the font cache at bootup. The side effect is slightly increased boot time, but if you have a reasonably robust hardware configuration (SSDs, fast processor, a good amount of memory, etc.), this increased boot time should not be that noticeable. (My systems are particularly well-endowed in terms of such resources and also have close to 2000 typefaces installed. I see no noticeable difference in boot times!)
          I have attached two registry files. To avoid problems of “issues” with e-mail and other systems censoring .reg suffix file attachments, I have renamed them with a .rex file suffix. Change the file suffixes to .reg to be able to double-click and apply the registry changes. (You may need to extract these files from a .zip container first!)
          Use file Temp_Fix_Windows_10_Creators_Update_LinkedFont_Bug.reg to install the temporary fix:
          File Contents:
          Windows Registry Editor Version 5.00
          [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\GRE_Initialize]
          "DisableFontBootCache"=dword:00000001
          Obviously, you will need to reboot your system after having applied this registry change.
          Use file Undo_Temp_Fix_Windows_10_Creators_Update_LinkedFont_Bug.reg to remove the temporary fix (you'll need to use this prior to installing the Windows 10 Creators Fall Update):
          File Contents:
          "DisableFontBootCache"=-
          Microsoft offered a second workaround which I don't recommend –  deleting the font cache file as part of the logoff process. This effectively accomplishes the same thing with the same increased boot time, but quite frankly, if a system crashes or otherwise reboots without logoff, you can't count on this workaround since a logoff script won't be run.
          I'll update this thread if and when I get further information from Microsoft confirming that the fix has been made, tested, and included in the Windows 10 Creators Fall Update (or if miraculously, an earlier fix is made available)!
                - Dov
          • 3. Re: Problems in Windows 10 Creators Update with Fonts Installed via “Shortcut”!
            BobLevine MVP & Adobe Community Professional
            Thanks for the update, Dov. Hopefully we’ll see the Fall Creators Update in September. I’m running the insider preview and the last build had a welcome to the fall creators update screen upon launch.
            • 4. Re: Problems in Windows 10 Creators Update with Fonts Installed via “Shortcut”!
              nachtlicht63
              Thank, Dov!
              The temp fix did work for me - your help is much appreciated
              • 5. Re: Problems in Windows 10 Creators Update with Fonts Installed via “Shortcut”!
                johnl92528346 Level 1
                Thanks Dov
                The fix worked perfectly.
                You are a star, I have been trying to locate where the problem was for days .
                Really appreciated
                • 6. Re: Problems in Windows 10 Creators Update with Fonts Installed via “Shortcut”!
                  October 29 , 2017
                  Having just installed the Windows 10 Creators Fall Update on three of my systems and having done multiple reboots and significant work in applications (Adobe and Microsoft) using fonts that installed via links, I am happy to announce that Microsoft has finally fixed this problem.
                  Assuming that you used the patch that I provided in this thread to temporarily mask the problem, you should now apply the registry patch with removes that temporary workaround. Download, unzip, and run the registry patch attached, file Undo_Temp_Fix_Windows_10_Creators_Update_LinkedFont_Bug.reg to remove the temporary fix (you should to use this prior to installing the Windows 10 Creators Fall Update, but there should be no harm if you run it after the update installs):
                  File Contents:
                  If anyone is still having issues with this problem after installing the Windows 10 Creators Fall Update, please contact me via private message on these forums.
                        - Dov
