7 Replies Latest reply on Aug 14, 2017 5:09 AM by Karl Heinz Kremer
    How can I connect to an API and import JSON or XML data into a form field?
    BurtonDev
      I referenced the Javascript documentation and tried using a Net.HTTP.request. The documentation only shows an example of how to do an MKCOL request, not a GET request.
      If I hard-code the cURL value, I get the value "undefined". If I try passing it through a variable (as in the example below), I get the error "Invalid Arguments".
      My code looks something like this:
      foo = app.trustedFunction(function (cURL) {
          app.beginPriv();
          var params = {
             cVerb: "GET",
             cURL: cURL,
             oHandler: {
                  response: function (msg, uri, e) {
                      var stream = msg;
                      var string = "";
                      string = SOAP.stringFromStream(stream);
                      console.println(string);
                      console.println(stream);
          Net.HTTP.request(params);
          app.endPriv();
      foo("http:/api.somesite.com/data?q=param&apikey=123xyz&mode=xml");
      (I didn't try passing data to the form yet, but just tested out the code by printing to the console first).
      I am assuming that the variables in the response function (msg, uri, e) are populated by the response from the server? I am not quite sure how to "grab" the data that I want, and why I am getting these errors. Also wondering if I can do it without using SOAP. Thanks in advance!
