2 Replies Latest reply on Jul 14, 2017 6:36 PM by Chuck Uebele
    create new fill layer behind image
    bradleya17648820
      I am currently selecting an image and resizing the canvas around it which works fine, however, I need to create a white fill layer and be placed at the end so I can use transparent images. I currently have some js which create a new fill layer but it sits on top and just gives me a blank white png file. If someone could show me how to place this below the image layer it would be create
        var NoImages = File.openDialog("Select your logo file", false);
          if (NoImages !== null) {
              var doc = open(NoImages, OpenDocumentType.PNG.JPEG); // Open PNG file
              if (doc == null) {
                throw "Something is wrong with the file.";
              var startState = doc.activeHistoryState;       // save for undo
              var initialPrefs = app.preferences.rulerUnits; // will restore at end
              app.preferences.rulerUnits = Units.PIXELS;     // use pixels
              // Folder selection dialog
              var destFolder = Folder.selectDialog( "Choose an output folder");
              if (destFolder == null) {
                // User canceled, just exit
                throw "";
              // Save icons in PNG using Save for Web.
              var sfw = new ExportOptionsSaveForWeb();
              sfw.format = SaveDocumentType.PNG;
              sfw.PNG8 = false; // use PNG-24
              sfw.transparency = true;
              doc.info = null;  // delete metadata
             var no_images = [
                {"name": "no-image-1-1", "width":1170, "height":1170},
                {"name": "no-image-2-3", "width":779, "height":1170},
                {"name": "no-image-3-2", "width":1170, "height":779},
                {"name": "no-image-3-4", "width":879, "height":1170},
                {"name": "no-image-4-3", "width":1170, "height":879},
                {"name": "no-image-7-2", "width":1170, "height":334},
                {"name": "no-image-9-3", "width":1170, "height":391},
                {"name": "no-image-11-5", "width":1170, "height":532},
                {"name": "no-image-16-9", "width":1170, "height":658}
              var no_image;
              for (i = 0; i < no_images.length; i++)  {
                  no_image = no_images[i];
                  doc.resizeCanvas(no_image.width, no_image.height, // width, height
                  null, ResampleMethod.BICUBICSHARPER);
                  var layerRef = app.activeDocument.artLayers.add();
                  layerRef.name = "fill";
                  var myColor = new SolidColor();
                  myColor.rgb.red = 255;
                  myColor.rgb.green = 255;
                  myColor.rgb.blue = 255;
                  activeDocument.selection.fill( myColor);
                  var destFileName = no_image.name + ".png";
                  doc.exportDocument(new File(destFolder + "/" + destFileName), ExportType.SAVEFORWEB, sfw);
                  doc.activeHistoryState = startState; // undo resize
          alert("No Images created!");
        • 1. Re: create new fill layer behind image
          I'm trying to understand what you are trying to do.  It looks like you are coding resize canvas like your are doing a resize image.  the statement is all wrong its just width height and anchor point. If you were to resize your logo not the canvas but the image it would get more and more distorted by these unconstrained image resize.  Why would you want to put your logo  the same size on nine different size white canvases which I think is what you are trying to do. Where would you like your logo to be  on each canvas?   Normally you place your logo on image. sized for the image's size and resolution.   That is very easy to do. I have posted as script to do the several times.
          Here it is again with a slight change you can position you logo in the lower left or right corner now.
          #target photoshop;
          app.bringToFront();
          var logoFile = "~/Desktop/JJMack.png"; // Watermark file should be large for resize down works better than up
          var LogoSize = 10; // percent of document height to resize Watermark to
          var LogoMargin = 1;                                         // percent of Document height the Watermark should have as a margin
          var BottomLetf = false; // false = Bottom Right true Bottom Left
          placeWatermark(logoFile, LogoSize, LogoMargin);             // Place Watermark  into the bottom right of document
          function placeWatermark(Image,Size,Margin){
          if(!documents.length) return;   // if no document return
          try{
          var doc = app.activeDocument; // set Doc object to active document
          app.displayDialogs = DialogModes.NO; // Dialog off
          var strtRulerUnits = app.preferences.rulerUnits; // Save Users ruler units
          var strtTypeUnits = app.preferences.typeUnits; // Save Users Type units
          app.preferences.rulerUnits = Units.PIXELS; // work with pixels
          app.preferences.typeUnits = TypeUnits.PIXELS; // work with pixels
          var fileObj = new File(Image);                 // the passed file
          if(!fileObj.exists){   // If file does not exits tell user
          alert(fileObj.name  + " does not exist!");
          return;
          placeFile(fileObj); // Place in file the Watermark png file
          activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER); // Insure Place did not scale layer
          var SB = activeDocument.activeLayer.bounds; // get layers bounds
          var layerHeight = SB[3] - SB[1]; // get layers height
          var resizePercent = (100/layerHeight)*(Size/100*doc.height.value); // Percent to resize by
          activeDocument.activeLayer.resize(resizePercent ,resizePercent,AnchorPosition.MIDDLECENTER);  // Resize width and height by percentage
          SB = activeDocument.activeLayer.bounds; // get resized layers bounds
          activeDocument.activeLayer.translate(-SB[0].value,-SB[1].value); // Move resized layer to top left canvas corner
          var LayerWidth = (SB[2].value - SB[0].value);
          var LayerHeight = (SB[3].value - SB[1].value);
          marginSize = Margin/100*doc.height.value; // Margin size
          // move resized watermark into the document lower right corner with some margin or lower left
          if  ( BottomLetf) {activeDocument.activeLayer.translate(marginSize,( doc.height.value -marginSize - LayerHeight));}
          else {activeDocument.activeLayer.translate((doc.width.value -marginSize - LayerWidth),( doc.height.value -marginSize - LayerHeight));}
          catch(e) { alert(e + ': on line ' + e.line); } // inform user of error
          finally{
          app.preferences.rulerUnits = strtRulerUnits; // Restore user ruler units
          app.preferences.typeUnits = strtTypeUnits; // Restore user type units
          function placeFile(placeFile) {
              var desc21 = new ActionDescriptor();
              desc21.putPath( charIDToTypeID('null'), new File(placeFile) );
              desc21.putEnumerated( charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), charIDToTypeID('Qcsa') );
              var desc22 = new ActionDescriptor();
              desc22.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), 0.000000 );
              desc22.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), 0.000000 );
              desc21.putObject( charIDToTypeID('Ofst'), charIDToTypeID('Ofst'), desc22 );
              executeAction( charIDToTypeID('Plc '), desc21, DialogModes.NO );
          • 2. Re: create new fill layer behind image
            Chuck Uebele Adobe Community Professional & MVP
            Try adding this to your script:
            createFill ();
            var fillLayer = doc.activeLayer;
            fillLayer.move(doc.layers[doc.layers.length-1], ElementPlacement.PLACEAFTER)
            function createFill(){
                var idMk = charIDToTypeID( "Mk  " );
                    var desc4 = new ActionDescriptor();
                    var idnull = charIDToTypeID( "null" );
                        var ref1 = new ActionReference();
                        var idcontentLayer = stringIDToTypeID( "contentLayer" );
                        ref1.putClass( idcontentLayer );
                    desc4.putReference( idnull, ref1 );
                    var idUsng = charIDToTypeID( "Usng" );
                        var desc5 = new ActionDescriptor();
                        var idType = charIDToTypeID( "Type" );
                            var desc6 = new ActionDescriptor();
                            var idClr = charIDToTypeID( "Clr " );
                                var desc7 = new ActionDescriptor();
                                var idRd = charIDToTypeID( "Rd  " );
                                desc7.putDouble( idRd, 255.000000 );
                                var idGrn = charIDToTypeID( "Grn " );
                                desc7.putDouble( idGrn, 255.000000 );
                                var idBl = charIDToTypeID( "Bl  " );
                                desc7.putDouble( idBl, 255.000000 );
                            var idRGBC = charIDToTypeID( "RGBC" );
                            desc6.putObject( idClr, idRGBC, desc7 );
                        var idsolidColorLayer = stringIDToTypeID( "solidColorLayer" );
                        desc5.putObject( idType, idsolidColorLayer, desc6 );
                    desc4.putObject( idUsng, idcontentLayer, desc5 );
                executeAction( idMk, desc4, DialogModes.NO );
