2 Replies Latest reply on May 22, 2006 12:30 PM by JstMrd
    Using Variable Name problem with this_x
    JstMrd Level 1
      Hello to all (on a Sunday afternoon),
      Briefly: Trying to load 32 movie clips (via the script below) onto the stage (dynamically). In theory, each clip (or box) will load through a For Loop and each name of the clip is loaded through the number created by the loop. The problem is the x and y position is ignored ONLY when I insert a variable name instead of "this" in f "this._x" or "this._y". (The variable I am using is _global.cl_Name) The clips load fine but all in the upper left hand corner of the stage.
      Any help or variation on this theme would be appreciated.
      D.
