Sorry if this has already been answered, but I didn't find any post exactly like it.
I used to be able to export edited photos to original folders but now, as soon as I import photos into Lightroom, folders are set up in a 2017 folder in Pictures with the current date and then considers THAT the original folder, which it is not. I do not want pics exported to a folder it makes up, it makes an extra step for me. I want them going back to the original folder I imported them from, which is never in Pictures.
I don't know what settings are needed to look at, so have just attached the Export window. As others have tried to fix similar issues, I've deleted preference files. I'm probably missing a setting somewhere, but don't know where. Can anyone help with this? Thanks.
I believe you problem is in your Import method.
When you Import photos from your hard-drive you should be using the "ADD" option (above the window) so that the photos are not copied or moved to a new location. (The new location being the 2017 folder)
Using "ADD" will add the photos to the catalog library but leave them on the hard drive in their 'original' hard-drive folder wherever they are.
If you "Copy" or "Move",
...Copy link to clipboard
If you "Copy" or "Move", you are creating a new location for the photos and Lightroom now sees that as the folder where the 'original' files are stored in your computer. (Also "Copy" creates duplicates of all the photos on your hard-drive)
Now your Export to "Same folder as original" will work as you expect.
That did it! Thank you soooo much. This has been bugging me for months, but I don't ever recall clicking "add" to import to get edited photos back into the original folder. Anyway, it works and I'm grateful.
