4 Replies Latest reply on Jul 16, 2017 3:24 AM by PippoApps
    BUG: Impossible to work with Components in Animate CC 2017.5 - 16.5.1.104
    PippoApps Level 1
      1 - Copy a component in one layer
      2 - Paste it in another layer
      Result: NOTHIG HAPPENS
      1 - Copy a component in a document library
      2 - Paste it in another document library
      Result: only folders of component assets get created in new library, none of the assets appears.
      1 - Drag a component from library to stage in an empty layer
      Result: screen flickers, nothing happens. Layer stays empty.
      The only way is create a movieclip with the component inside, drag it to stage, then brak apart, and use the component.
      You can try in attached fla (if I manage to attach it), to copy from one layer to another.
      THIS IS NOT THE FIRST TIME A NEW RELEASE BREAKS COMPONENTS USAGE.
      PLEASE CHECK COMPONENTS USAGE BEFORE RELEASING NEW VERSIONS.
