4 Replies Latest reply on Jul 17, 2017 4:31 AM by JJMack
    Photoshop 2017 Crashes
    kathleeno8245412
      Normally Photoshop runs fine on my machine but today all of a sudden it's running slow when using the move or transform tool and then crashes. I am on a surface book pro with windows 10 pro, and i7 6600 2.60ghz, 16gb ram, and an Nvidia 965m. The machine is well capable of running Photoshop and has performed well in the past, even earlier today, until just now. Over the past few days adobe spaces helper.exe has crashed but the problems didn't start until today. I have tried turning off the gpu acceleration, changing performance settings, opening without plug-ins and nothing has worked. While running, the cpu, memory and disk are all running normally, with all of them maxing around 30%. I am very confused and need a solution quickly. Thank you for any help that you can offer me.
      here is a pastebin link to my sysinfo text from photoshop:
      kathleen photoshop sysinfo - Pastebin.com
      reliability history:
      spaces helper info:
        • 1. Re: Photoshop 2017 Crashes
          Many seem to have this problem.  I have the cc 2017 problem on one Windows 10Previer machine, With a nvidiai Quadro 4000.  My surface pro 3  Windows 10 preview system  does not have this problem.  My wife's workstation Windows 10 not preview with a nvidia Quadeo K2200 does not have this problem.  I have read all the threads and tries all the work around written about. My Machine still crashes none of the work arounds posted in the threads I have read work for me.  When I use CC 2014  I do not have a problem
          • 2. Re: Photoshop 2017 Crashes
            Mohit Goyal Adobe Employee (Admin)
            Hi kathleeno,
            Please refer the below troubleshooting article related to this issue.
            Photoshop crashing due to libcef.dll
            Let us know if that helps.
            Regards,
            Mohit
            • 3. Re: Photoshop 2017 Crashes
              Tried all steps before, Any time I try to stroke a path CC 2017 Photoshop would crash followed by two Spaces Helper crashes on my workstation with an Nvidia Quadro 4000 I do not have a Problem on my Surface Pro 3 with Intel HD Graphice..  So since I just installed yot another Windows Preview build  I tried thes solution again. Photoshop Still crashes however the following two Spaces  Helper crashes in libcef.dll do not happen. Only Photoshop.exe crashes. Just my Workstation with the Quadro 4000.  CC 2014 works well.]
              Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
              Number of Launches: 590
              Version: 10 or greater
              System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
              Physical processor count: 12
              Logical processor count: 24
              Processor speed: 1995 MHz
              Built-in memory: 40886 MB
              Free memory: 22598 MB
              Memory available to Photoshop: 36911 MB
              Memory used by Photoshop: 70 %
              History Thumbnails: Disabled.
              Touch Bar: Disabled.
              Alias Layers: Disabled.
              Modifier Palette: Disabled.
              Highbeam: Enabled.
              Image tile size: 1028K
              Image cache levels: 6
              Font Preview: Medium
              TextComposer: Latin
              Display: 1
              Display Bounds: top=0, left=0, bottom=1080, right=1920
              Display: 2
              Display Bounds: top=0, left=-1360, bottom=768, right=0
              OpenGL Drawing: Enabled.
              OpenGL Allow Old GPUs: Not Detected.
              OpenGL Drawing Mode: Normal
              OpenGL Allow Normal Mode: True.
              OpenGL Allow Advanced Mode: False.
              AIFCoreInitialized=1
              AIFOGLInitialized=1
              OGLContextCreated=1
              NumGLGPUs=1
              NumCLGPUs=1
              NumNativeGPUs=0
              glgpu[0].GLVersion="4.1"
              glgpu[0].IsIntegratedGLGPU=0
              glgpu[0].GLMemoryMB=2048
              glgpu[0].GLName="NVIDIA Quadro 4000"
              glgpu[0].GLVendor="NVIDIA Corporation"
              glgpu[0].GLVendorID=4318
              glgpu[0].GLDriverVersion="21.21.13.7735"
              glgpu[0].GLRectTextureSize=16384
              glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
              glgpu[0].GLRendererID=1757
              glgpu[0].HasGLNPOTSupport=1
              glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db3 5200ede2a85a\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2 db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd 64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf _amd64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi .inf_amd64_2db35200ede2a85a\nvd3dum,C:\WINDOWS\System32\DriverStore\FileRepository\nv_disp wi.inf_amd64_2db35200ede2a85a\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_d ispwi.inf_amd64_2db35200ede2a85a\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\n v_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2um"
              glgpu[0].GLDriverDate="20170501000000.000000-000"
              glgpu[0].CanCompileProgramGLSL=1
              glgpu[0].GLFrameBufferOK=1
              glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
              glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
              glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
              glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
              glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
              glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
              glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
              glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
              glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
              glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
              glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
              glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
              glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
              clgpu[0].CLPlatformVersion="1.2"
              clgpu[0].CLDeviceVersion="1.1 CUDA"
              clgpu[0].IsIntegratedCLGPU=0
              clgpu[0].CLMemoryMB=2048
              clgpu[0].CLName="Quadro 4000"
              clgpu[0].CLVendor="NVIDIA Corporation"
              clgpu[0].CLVendorID=4318
              clgpu[0].CLDriverVersion="377.35"
              clgpu[0].CLBandwidth=7.47754e+10
              clgpu[0].CLCompute=191.694
              License Type: Subscription
              Serial number: 90970090970448917498
              GUIDBucket:
                bucket: 235
                test: DocumentPanel
              Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
              Temporary file path: C:\Users\JOHNJM~1\AppData\Local\Temp\
              Photoshop scratch has async I/O enabled
              Scratch volume(s):
                E:\, 3.64T, 3.10T free
              Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
              Primary Plug-ins folder: not set
              Installed components:
                 A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                 ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
                 AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                 AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                 AdobeOwl.dll   Adobe Owl   5.2.11
                 AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                 AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                 AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
                 AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                 AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                 AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                 adobe_caps.dll   Adobe CAPS   10,0,0,6
                 AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
                 ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
                 AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                 amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
                 ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
                 AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                 AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                 Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
                 BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
                 boost_date_time.dll   photoshopdva   10.0.0
                 boost_signals.dll   photoshopdva   10.0.0
                 boost_system.dll   photoshopdva   10.0.0
                 boost_threads.dll   photoshopdva   10.0.0
                 cg.dll   NVIDIA Cg Runtime   3.0.00007
                 cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                 CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                 CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
                 dnssd.dll   Bonjour   3,0,0,2
                 dvaaudiodevice.dll   photoshopdva   10.0.0
                 dvacore.dll   photoshopdva   10.0.0
                 dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                 dvamarshal.dll   photoshopdva   10.0.0
                 dvamediatypes.dll   photoshopdva   10.0.0
                 dvametadata.dll   photoshopdva   10.0.0
                 dvametadataapi.dll   photoshopdva   10.0.0
                 dvametadataui.dll   photoshopdva   10.0.0
                 dvaplayer.dll   photoshopdva   10.0.0
                 dvatransport.dll   photoshopdva   10.0.0
                 dvaui.dll   photoshopdva   10.0.0
                 dvaunittesting.dll   photoshopdva   10.0.0
                 dynamiclink.dll   photoshopdva   10.0.0
                 ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
                 icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                 icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                 icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                 igestep30.dll   IGES Reader   9.3.0.113
                 imslib.dll   IMSLib DLL   10.0.0.11
                 JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
                 libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                 libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                 libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                 LogSession.dll   LogSession   7.4.1.60.45263
                 mediacoreif.dll   photoshopdva   10.0.0
                 MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                 pdfsettings.dll   Adobe PDFSettings   1.04
                 Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
                 Plugin.dll   Adobe Photoshop CC 2017   18.1.1
                 PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                 PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                 PSArt.dll   Adobe Photoshop CC 2017   18.1.1
                 PSViews.dll   Adobe Photoshop CC 2017   18.1.1
                 SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
                 SVGRE.dll   SVGRE   79.579975   79.579975
                 svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                 tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                 tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                 TfFontMgr.dll   FontMgr   9.3.0.113
                 TfKernel.dll   Kernel   9.3.0.113
                 TFKGEOM.dll   Kernel Geom   9.3.0.113
                 TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                 updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                 VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                 VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                 WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                 wu3d.dll   U3D Writer   9.3.0.113
              Required plug-ins:
                 3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Accented Edges 18.1.1 - from the file “Filter Gallery.8bf”
                 Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle.8bf”
                 Angled Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                 Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average.8bf”
                 Bas Relief 18.1.1 - from the file “Filter Gallery.8bf”
                 BMP 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Camera Raw 9.10.1 - from the file “Camera Raw.8bi”
                 Camera Raw Filter 9.10.1 - from the file “Camera Raw.8bi”
                 Chalk && Charcoal 18.1.1 - from the file “Filter Gallery.8bf”
                 Chrome 18.1.1 - from the file “Filter Gallery.8bf”
                 Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon.8bi”
                 Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                 Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Color Halftone 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Colored Pencil 18.1.1 - from the file “Filter Gallery.8bf”
                 CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Conté Crayon 18.1.1 - from the file “Filter Gallery.8bf”
                 Craquelure 18.1.1 - from the file “Filter Gallery.8bf”
                 Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto.8li”
                 Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Crosshatch 18.1.1 - from the file “Filter Gallery.8bf”
                 Crystallize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Cutout 18.1.1 - from the file “Filter Gallery.8bf”
                 Dark Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                 De-Interlace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Dicom 18.1.1 - from the file “Dicom.8bi”
                 Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                 Diffuse Glow 18.1.1 - from the file “Filter Gallery.8bf”
                 Displace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Dry Brush 18.1.1 - from the file “Filter Gallery.8bf”
                 Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire.8ba”
                 Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                 Extrude 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore.8bx”
                 Fibers 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Film Grain 18.1.1 - from the file “Filter Gallery.8bf”
                 Filter Gallery 18.1.1 - from the file “Filter Gallery.8bf”
                 Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Fresco 18.1.1 - from the file “Filter Gallery.8bf”
                 Glass 18.1.1 - from the file “Filter Gallery.8bf”
                 Glowing Edges 18.1.1 - from the file “Filter Gallery.8bf”
                 Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Graphic Pen 18.1.1 - from the file “Filter Gallery.8bf”
                 Halftone Pattern 18.1.1 - from the file “Filter Gallery.8bf”
                 HDRMergeUI 18.1.1 - from the file “HDRMergeUI.8bf”
                 HSB/HSL 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 IFF Format 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Ink Outlines 18.1.1 - from the file “Filter Gallery.8bf”
                 JPEG 2000 18.1.1 - from the file “JPEG2000.8bi”
                 Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Lens Blur 18.1.1 - from the file “Lens Blur.8bf”
                 Lens Correction 18.1.1 - from the file “Lens Correction.8bf”
                 Lens Flare 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Liquify 18.1.1 - from the file “Liquify.8bf”
                 Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                 Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
                 Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Mezzotint 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore.8bx”
                 Mosaic Tiles 18.1.1 - from the file “Filter Gallery.8bf”
                 Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support.8bx”
                 Neon Glow 18.1.1 - from the file “Filter Gallery.8bf”
                 Note Paper 18.1.1 - from the file “Filter Gallery.8bf”
                 NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors.8bf”
                 Ocean Ripple 18.1.1 - from the file “Filter Gallery.8bf”
                 OpenEXR 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Paint Daubs 18.1.1 - from the file “Filter Gallery.8bf”
                 Palette Knife 18.1.1 - from the file “Filter Gallery.8bf”
                 Patchwork 18.1.1 - from the file “Filter Gallery.8bf”
                 Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX.8bi”
                 Photocopy 18.1.1 - from the file “Filter Gallery.8bf”
                 Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine.8bi”
                 Photoshop Touch 14.0 - from the file “PSDX.8bi”
                 Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                 Pinch 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar.8bi”
                 Plaster 18.1.1 - from the file “Filter Gallery.8bf”
                 Plastic Wrap 18.1.1 - from the file “Filter Gallery.8bf”
                 PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 PNG 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Pointillize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM.8bi”
                 Poster Edges 18.1.1 - from the file “Filter Gallery.8bf”
                 PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Radial Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance.8bi”
                 Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                 Reticulation 18.1.1 - from the file “Filter Gallery.8bf”
                 Ripple 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Rough Pastels 18.1.1 - from the file “Filter Gallery.8bf”
                 Save for Web 18.1.1 - from the file “Save for Web.8be”
                 ScriptingSupport 18.1.1 - from the file “ScriptingSupport.8li”
                 Shake Reduction 18.1.1 - from the file “Shake Reduction.8bf”
                 Shear 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Smart Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Smudge Stick 18.1.1 - from the file “Filter Gallery.8bf”
                 Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize.8bf”
                 Spaces 18.1.1 - from the file “Spaces.8li”
                 Spatter 18.1.1 - from the file “Filter Gallery.8bf”
                 Spherize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Sponge 18.1.1 - from the file “Filter Gallery.8bf”
                 Sprayed Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                 Stained Glass 18.1.1 - from the file “Filter Gallery.8bf”
                 Stamp 18.1.1 - from the file “Filter Gallery.8bf”
                 Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Sumi-e 18.1.1 - from the file “Filter Gallery.8bf”
                 Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Targa 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Texturizer 18.1.1 - from the file “Filter Gallery.8bf”
                 Tiles 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Torn Edges 18.1.1 - from the file “Filter Gallery.8bf”
                 Twirl 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Underpainting 18.1.1 - from the file “Filter Gallery.8bf”
                 Vanishing Point 18.1.1 - from the file “VanishingPoint.8bf”
                 Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                 Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 Water Paper 18.1.1 - from the file “Filter Gallery.8bf”
                 Watercolor 18.1.1 - from the file “Filter Gallery.8bf”
                 Wave 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                 WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport.8li”
                 Wind 18.1.1 - from the file “Standard MultiPlugin.8bf”
                 Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP.8bi”
                 ZigZag 18.1.1 - from the file “Standard MultiPlugin.8bf”
              Optional and third party plug-ins: NONE
              (Note: Loading optional plug-ins is currently disabled.)
              Duplicate and Disabled plug-ins: NONE
              Plug-ins that failed to load: NONE
              Extensions:
                 com.adobe.inapp.purchase  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
                 New Document  2.0.0 - from the file “C:\Users\John J McAssey\AppData\Roaming\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_0_0_003\fnft.html”
                 Libraries  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
                 com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
                 Start  2.0.0 - from the file “C:\Users\John J McAssey\AppData\Roaming\Adobe\CEP\extensions\CCX_START_EXTENSION_2_0_0_042\index.html”
                 Adobe Color Themes  6.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\KulerPanelHTMLBundle\index.html”
                 Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                 Device Preview  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
                 JSX Launcher  0.1.4 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\net.sytes.chuwa.jsxlauncher\index.html”
                 com.adobe.preview.loader  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
              Installed TWAIN devices: NONE
              • 4. Re: Photoshop 2017 Crashes
                With the latest Windows 10 Preview 16241. I can enable OpenCL and my third party  plugin and Spacer Helper.exe will not crash if Show Messages is not checked im My Photoshop preferences Just Photoshop.exe does. If Show Messages is check when I try to stroke a Path Photoshop willl crash and Spaces Helper will crash twice after Photoshop crashes.
