2 Replies Latest reply on Jul 24, 2017 5:47 PM by RiadMed
    "File/Folder Expected" Error
      I cannot seem to debug an error I am getting from an Applescript that is adapted from the business card template that ships with Illustrator. Specifically, at the line "update dataset i of document currentDoc" I am getting an error "File/Folder expected." I am happy to post the entire script but, before doing so, does anyone see anything obviously wrong with the below which may be causing this error?
      Thank you in advance for any assistance:
        tell application "Adobe Illustrator"
        set mysetcount to myindex - 1
        repeat with i from 1 to mysetcount
        import variables document currentDoc from alias XMLfilePath
        set pathText to item i of filePaths
        set mynewfile to exportFolder & "CaseNo" & i & "-productsource.pdf" as string
        set myfile to file path of document currentDoc
        save document currentDoc in file mynewfile as pdf
        close document 1 saving no
        open myfile
        end repeat
        end tell
        end if
      end batchExport
        • 1. Re: "File/Folder Expected" Error
          Silly-V Adobe Community Professional
          These always get me, for me I always have to think and re-think how the files and folders an POSIX files and POSIX folders and paths of each all relate to each other in AppleScript. Then, after much trial and error I have some snippet which I copy/paste across all my AppleScripts. In my case it's always been a matter of converting regular files/folders to POSIX ones and vice-versa.
          • 2. Re: "File/Folder Expected" Error
            RiadMed Level 1
            Just add a delay after importing variables to compensate for the time the variables gets loaded to illustrator., add this:
            delay 1
            hope it helps
