2 Replies Latest reply on Jul 17, 2017 5:23 AM by smithcgl9043167
    Help with scrollbar with ScriptUI
    smithcgl9043167 Level 2
      How to make the scrollbar work perfectly by showing the other buttons ("BT4" and "BT5") that were hidden inside the panel ??
      That was what I did, however, without success:
      var w = new Window("dialog");
      var g = w.add ("group");
      var panel = g.add("panel", [0,0,150,200]);
      var sbar = g.add ("scrollbar", [0,0,20,200]);
      sbar.onChanging = function () {$.writeln (sbar.value)}
      var b1 = panel.add("button", [0,0,0,0], "BT1")
      b1.location = [10, 12]
      b1.size = [120, 50]
      var b2 = panel.add("button", [0,0,0,0], "BT2")
             b2.location = [10, 70]
             b2.size = [120, 50]
      var b3 = panel.add("button", [0,0,0,0], "BT3")
             b3.location = [10, 128]
             b3.size = [120, 50]
      var b4 = panel.add("button", [0,0,0,0], "BT4")
            b4.location = [10, 186]
            b4.size = [120, 50]
      var b5 = panel.add("button", [0,0,0,0], "BT5")
            b5.location = [10, 245]
            b5.size = [120, 50]
      w.show();
      All tips and help will be valid. Thank you in advance.
        • 1. Re: Help with scrollbar with ScriptUI
          MBA-2-rae Level 1
          perhaps this could be of some help for you:
          Scrollable panel gets truncated
          Hans
          • 2. Re: Help with scrollbar with ScriptUI
            Hi MBA-2-rae. Thanks for the link! I have seen here this beautiful example, unfortunately I am very new to Scripting and have not been able to add my respective buttons in this script below. This is a bit tricky for my head. If please someone with more knowledge can show me replace the text options with individual buttons, I will be eternally grateful.
            var w = new Window('dialog');
            w.maximumSize.height = 300;
            var panel = w.add ('panel {alignChildren: "left"}');
            var scrollGroup = panel.add('group {orientation: "column", alignChildren: "left", spacing: 5}');
            var numItems = 500;
            var itemHeight, scrollGroupActualHeight;
            for (var i = 0; i < numItems; i++) {
                scrollGroup.add('statictext', undefined, 'Label ' + i);
            var scrollBar = panel.add('scrollbar {stepdelta: 1}');
            scrollBar.onChanging = function () {
                var children = scrollGroup.children;
                var n;
                for (n=0; n<numItems; n++){
                    children[n].location.y = (n-this.value)*itemHeight;
            w.onShow = function() {
                // Set various sizes and locations when the window is drawn
                panel.size.height = w.size.height-20;
                scrollBar.size.height = w.size.height-40;
                scrollBar.size.width = 20;
                scrollBar.location = [panel.size.width-30, 8];
                itemHeight = scrollGroup.children[0].size[1]+scrollGroup.spacing;
                scrollGroupActualHeight = panel.size[1] - panel.margins[1] - panel.margins[3];        // scrollGroup.size[1] is at the max value
                scrollBar.maxvalue = Math.ceil(numItems-(scrollGroupActualHeight/itemHeight));
            w.show();
