4 Replies Latest reply on May 24, 2006 10:06 AM by Newsgroup_User
    dynamic videos.
    Level 7
      how do i add a video on flash dinamically? (exrternal file loading on the
      fly)
      thanks.
        • 1. Re: dynamic videos.
          Level 7
          Hi!
          Check out
          http://www.gotoandlearn.com/
          Tutorials for .flv and .swf.
          /Jensen/
          "JimmySlam" <JimmySlam@hotmail.com> wrote in message
          news:e51ogt$m9s$1@forums.macromedia.com...
          > fly)
          > thanks.
          • 2. Re: dynamic videos.
            Level 7
            well i need to read mov, mpg , avi or what ever but not flv.
            Do you know how??
            "Jensen" <NoSpam@somewhere.no> wrote in message
            news:e51qa0$oj5$1@forums.macromedia.com...
            > Hi!
            > Check out
            > /Jensen/
            >> fly)
            >> thanks.
            • 3. Re: dynamic videos.
              Level 7
              Hi again!
              As far as I know, this is not possible to do dynamically in Flash. Flash
              supports only loading of .flv, .swf and .jpg, in additon to some sound
              formats. So as far as I can see, you can either implement some flash content
              on an html-page where you through user interaction in the flash load up the
              other movies somewhere else (outside flash) on the html-page, or you will
              have to convert the movies to .flv or .swf. You can for example import the
              movies in flash and compile it as .swf and then load those .swf. You can
              also use a program to convert the files. One product to do this is Sorenson
              Squeeze ( http://www.sorensonmedia.com/). At least one of the tutorials at
              the other site ( http://www.gotoandlearn.com/) shows an example of using this
              program. Another advantage with this is the possibility to compress the
              movies through encoding.
              /Jensen/
              news:e51scg$rg7$1@forums.macromedia.com...
              > Do you know how??
              >> Hi!
              >> Check out
              >> /Jensen/
              >>> the fly)
              >>> thanks.
              • 4. Re: dynamic videos.
                Level 7
                OK, tomorrow i will have a look at this, looks interesting
                Thanks!
                news:e51tk4$t63$1@forums.macromedia.com...
                > Hi again!
                > content on an html-page where you through user interaction in the flash
                > load up the other movies somewhere else (outside flash) on the html-page,
                > or you will have to convert the movies to .flv or .swf. You can for
                > example import the movies in flash and compile it as .swf and then load
                > those .swf. You can also use a program to convert the files. One product
                > to do this is Sorenson Squeeze ( http://www.sorensonmedia.com/). At least
                > one of the tutorials at the other site ( http://www.gotoandlearn.com/)
                > shows an example of using this program. Another advantage with this is the
                > possibility to compress the movies through encoding.
                > /Jensen/
                >> Do you know how??
                >>> Hi!
                >>> Check out
                >>> /Jensen/
                >>>> the fly)
                >>>> thanks.
