Expand my Community achievements bar.
SOLVED
Want to track logged in user and User's metadata
Avatar
Employee
I have a requirement to track how many users successfully logged in to my website along with their metadata e.g. their Role, Designation (that comes from the back-end and is available at the client side(Javascript) of the application).
I am using a DirectCall rule in DTM in the Login function's(Ajax call) Success callback where I capture user's username, name, designation and other related info which I want to track.
I have created a dataLayer like this:
dataLayer= {
            'pagename':pageName,
             'loggedInUser' : username,
             'designation' : designation,
             'UserRole' : role
I have captured this information in separate custom eVars and have to show this in a tabular format as shown below:
UserName  |   Designation  | UserRole  |  No.Of Views
How can this be achieved? Is my approach right, or I can use some predefined eVars or mechanism in place?
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
No They are not integrated with AA Dashboards but you can create you own dashboard using the Repoting API.
Analytics will only do breakdown style reports.
The solution that was explained above the send all the details in one report can achieve what you want.
If you send in an eVar : username | Designation | UserRole then it will appear as is, as a line item, then you will just have to add metric No.Of Views
View solution in original post
Avatar
Employee Advisor
Actually, you can just use one evar and get in the concatenated value of the 4 attributes. Once collected, you can classify them into separate reports and then do your analysis.
However, make sure that the username (or any attribute) is obscure and does not fall in PII.
Avatar
Employee
Hi hyderziaee​ You mean something like below to be captured in an eVar:
UserA, UserRoleofA, DesignationofA
and than classify them into separate reports.
Isn't this the same thing if I capture all these 3 KPIs (User, Role and Designation) in 3 seperate eVars and this will give me 3 reports ?
My problem was to show these 3 things in a tabular form in some report. Is that possible?
Avatar
Employee
Tabular as shown in my original post.
Avatar
Community Advisor
Per your initial post you said you already captured the data and you want to display the data in this way:
Try Data Warehouse or Reporting API .
There is also Report Builder plugin for excel
You could also check Google Data Studio that allows you to create custom reports. There is an Adobe Analytics connector.
Avatar
Employee
I want to have such a report in Adobe Analytics Dashboard. Is that possible?
Are API and Data Warehouse solutions integrated in AA Dashboards?
Avatar
Correct answer by
Community Advisor
