• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to remove mask trace ?
Participant ,
Jul 16, 2017 Jul 16, 2017
I don't want this mark made by a mask, how can I remove it please ?
2017-07-16 14_25_47-Adobe After Effects CC 2017 - Untitled Project.aep _.png
Views
826
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jul 16, 2017 Jul 16, 2017
you are not seeing the mask overlay, but the result matte composite out of combination of the effect and the mask. the mask render first, then effects - causing this outline. you should work your way around the problem like setting the mask in a different layer and use it as an alpha matte. alpha matte will render last so effects, then masks...
Votes
Translate
Translate
Community Expert ,
Click on the Show Mask button in the bottom of the composition panel (the button in blue)
Votes
Translate
Translate
Report
Report
Participant ,
Thank you for the answer, I found a "toggle mask and shape path visibility" it was enabled in blue, I clicked on it but you can still see the trace of the mask...
Votes
Translate
Translate
Report
Report
LEGEND ,
I am not sure this is a layer mask. where are the vertices? press UU on your layer and show us the full interface one more time.
Votes
Translate
Translate
Report
Report
Participant ,
2017-07-16 16_53_05-Adobe After Effects CC 2017 - E__Documents_After Effects_dedodublement vraiment..png
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
Participant ,
Thank you I think I understood the problem but to be honest, I have a hard time understanding what you told me Could you give me more details please ?
Votes
Translate
Translate
Report
Report
LEGEND ,
you need to create you matte in a different way. There is another approach than the one I mentioned that is easier - Try this:
Twirl down the difference matte effect in the timeline panel and you will see a Plus sign in the compositing options. Click on the plus sign. Now the effect will be restricted to the mask but in a different manner That won't introduce the edge.
Votes
Translate
Translate
Report
Report
Participant ,
It does not work unfortunately... :s :
2017-07-16 22_53_12-Adobe After Effects CC 2017 - E__Documents_After Effects_dedodublement vraiment..png
The whole background should be black and it does not :s
Votes
Translate
Translate
Report
Report
Participant ,
But I managed to do it as you said the first time i think 2017-07-16 22_58_23-Adobe After Effects CC 2017 - E__Documents_After Effects_dedodublement vraiment..png
Votes
Translate
Translate
Report
Report
LEGEND ,
Jul 17, 2017 Jul 17, 2017
LATEST
yes I see now the second approach won't do. the effect is only applied on the mask section but the layer is rendered as well. so the first approach works. Great
Votes
Translate
Translate
Report
Report
