2 Replies Latest reply on Dec 24, 2008 2:20 AM by André Pereira
    AdvancedDataGrid index issue
    André Pereira
      Hello,
      I'm having some issues with the index of an advancedatagrid, for example, i noticed that the index of my objects in the datagrid are not the same of the index in my dataprovider, if i keep all the nodes of the advanceddatagrid closed, i have a index that are not the same index if i open all the nodes.
      In my application a have the index of a line for example, and with that, i need to get the object in my dataprovider.
      ps: i dont have the item in the datagrid selected.
      Any ideias?
      thanks,
      Andrlop.
        • 1. Re: AdvancedDataGrid index issue
          Level 7
          "andrlop" <webforumsuser@macromedia.com> wrote in message
          news:giqgj0$ki0$1@forums.macromedia.com...
          > Hello,
          > i
          > the
          > nodes.
          I think you can treat each "level" of a HierarchicalData object as if it is
          an ArrayCollection, in which case you can use getItemIndex().
          HTH;
          Amy
          • 2. Re: AdvancedDataGrid index issue
            André Pereira Level 1
            > Hello,
            > i
            > the
            > nodes.
            HTH;
            Amy
            hm, do you have a example how can i do that? (sintax example).
            I found a way to solve my problem, i did a selectedIndex (he uses the array that i can see and not the dataprovider's array) in the advanceddatagrid and then i did a selectedItem to get que object in that row, but i think that is workaround alot.
