1 Reply Latest reply on Jul 17, 2017 7:28 AM by kglad
    Loading images on custom control events.
    rv38787797
      var LOADER:mx.controls.Loader;
      LOADER.load("download.png");
      var nextFileNameAbsol:String;
      var i:Number;
      var j:Number;
      var fileNameAbsol:String;
      var fileName:String;
      var fileArray:Array;
      fileName="version_01\\battery_0001.png" ;
      //my_txt3.htmlText="<img src=\"download.png\">";
      //trace("In main");
      //trace(this.mySlider.ratio);
      //trace("In main1");
      //trace(this.ratio);
      //trace("In main2");
      //trace(mySlider.ratio);
      this.onMouseDown==function(){
      trace("OnMD");
      ratio.text=this.mySlider.ratio;
      trace("in main ratio");
      //changeHandler();
      //changeHandler1();
      this.onMouseMove==function(){
      trace("OnMM");
      //changeHandler();
      //changeHandler1();
      this.onKeyDown==function(){
      trace("OnKD");
      //changeHandler();
      //changeHandler1();
      this.onLoad=function(){
      trace("Onload");
      //changeHandler();
      //changeHandler1();
      this.onEnterFrame=function(){
      //ratio.text=this.mySlider.ratio;
      //trace("in main ratio");
      //changeHandler();
      //changeHandler1();
      //stage.displayState = StageDisplayState.FULL_SCREEN_INTERACTIVE;
      //stage.scaleMode=StageScaleMode.NO_SCALE;
      //stage.align=StageAlign.TOP_LEFT;
      function changeHandler1():Void {
      trace("FCH");
      j=this.mySlider.ratio;
      fileNameAbsol= fileName.substr(0 ,(fileName.length-4));
      trace(fileNameAbsol);
      nextFileNameAbsol=generateName(fileNameAbsol,j);
      trace(nextFileNameAbsol);
      nextFileNameAbsol=nextFileNameAbsol+".png";
      fileName = nextFileNameAbsol;
      fileArray=nextFileNameAbsol.split("\\");
      //my_txt3.htmlText=htmlImage;
      function changeHandler():Void {
      var htmlImage:String;
      htmlImage="\"   <img src='";
      htmlImage+=fileArray[0];
      htmlImage+="/";
      //htmlImage+="\\\\";
      htmlImage+=fileArray[1];
      htmlImage+="' ";
      htmlImage+="height=\"42\" width=\"42\"";
      htmlImage+=" />    \"";
      //htmlImage+="' />    \"";
      trace("html im");
      trace(htmlImage);
      function leadingZeros(theNumber:Number):String{
      var ourString:String = String(theNumber);
      for(var i:Number = 4-ourString.length; i > 0; i--){
      ourString = "0"+ourString;
      return ourString;
      function generateName(fileName:String,end:Number):String{
      var fileNameRet:String;
      var len:Number;
      var nameEnd:Number;
      var stringPart:String;
      var stringPartNum:Number;
      var stringPartNumRet:String;
      var returnStringInipart:String;
      var returnString:String;
      trace("before ss");
      trace(fileName);
      stringPart=fileName.substr((fileName.length-4) ,(fileName.length-1));
      trace("after ss");
      trace(fileName);
      stringPartNum=Number(stringPart);
      stringPartNum++;
      stringPartNumRet=leadingZeros(j);
      returnStringInipart=fileName.substr(0 ,(fileName.length-4));
      trace("returnStringInipart");
      trace(returnStringInipart);
      trace("stringPartNumRet");
      trace(stringPartNumRet);
      returnStringInipart=returnStringInipart+stringPartNumRet;
      trace("returnStringInipart after cat");
      return returnStringInipart;
      In the above code, i want to load images to the LOADER as I use the mySlider.
      mySlider Code :
      //this.onEnterFrame=function(){
      // ratio.text=mySlider.ratio;
      // trace("tracing OS");
      // trace(mySlider.ratio);
      onClipEvent (load) {
      //mySound = new Sound();
      // mySound.loadSound("sound2.mp3", false);
      ratio.text=parent.mySlider.ratio;
      ratio.text="RAM";
        trace("onClipEvent load this ");
      trace("onClipEvent load parent ");
      trace(parent.mySlider.ratio);
      onClipEvent (enterFrame) {
      //downloaded = mySound.getBytesLoaded();
      // total = mySound.getBytesTotal();
      // if (downloaded != total) {
      _root.dl = "downloading song...";
      //} else {
      // complete = 1;
      // _root.dl = "";
      The code in mySlider:
      this.ratio=0;
      dragger.onPress=function(){
      //trace("drag");
      this.startDrag(true,0,0,line._width,0);
      ratio=Math.round(this._x) ;
      //trace("ratio");
      trace(ratio);
      dragger.onRelease=dragger.onreleaseOutside=stopDrag;
      ( The is a horizontal line  'Line ' and vertical 'dragger' Movieclip.
      How can i achieve this.
