2 Replies Latest reply on Aug 12, 2017 10:35 AM by MBA-2-rae
    User to select fill layer colour
    bradleya17648820 Level 1
      I currently have a fill layer function that creates a while layer.. simple
          function createFill() {
              var fillColor = new SolidColor();
              fillColor.rgb.red = 255;
              fillColor.rgb.green = 255;
              fillColor.rgb.blue = 255;
              var newLayer = doc.artLayers.add();
              newLayer.name = "fill " + (i + 1);
              doc.selection.fill(fillColor);
              newLayer.move(newLayer, ElementPlacement.PLACEAFTER);
              var fillLayer = doc.activeLayer;
              fillLayer.move(doc.layers[doc.layers.length-1], ElementPlacement.PLACEAFTER);
      Is there a way for the user to select a colour instead of hard coding it? Giving them the option of black or white?
      For example if the user was to use a logo as below with a white background it would not look so good. So it would be good to give them the option of a different colour for these situations
        • 1. Re: User to select fill layer colour
          Chuck Uebele Adobe Community Professional & MVP
          Do you want only black or white - no other colors or shades of gray? If so, you can create a simple UI with radio buttons for them to select either black or white.
          • 2. Re: User to select fill layer colour
            MBA-2-rae Level 1
            perhaps this function helps:
            #target photoshop
            function runColorPicker() {
              defColor = app.foregroundColor
              try {
              var bytes;
              var rgb = app.foregroundColor.rgb;
              bytes = (rgb.red << 16) + (rgb.green << 8) + rgb.blue;
              bytes = $.colorPicker(bytes);
              if (bytes != -1) {
              var c = new SolidColor();
              c.rgb.red = (bytes >> 16);
              c.rgb.green = (bytes >> 8) & 0xFF;
              c.rgb.blue = bytes & 0xFF;
              } catch (e) {alert(e)}
              return c;
            // call PS ColorPicker
            var color1 = runColorPicker();
            // show result
            alert(color1.rgb.red + ' ' + color1.rgb.green + ' ' + color1.rgb.blue)
