5 Replies Latest reply on Dec 23, 2008 11:49 AM by Newsgroup_User
    public override clone() -- errors
    jeffcg2 Level 1
      I'm working thru Adobe Flex 3 Training from the Source. And the CD is a Silver Frizbee. So there seems to some critical stuff that was on the CD.
      The product.as file is giving these errors, I read the error that there is supposed to be a clone() class.
      When I look in the Flex 3 help at all the classes there is none.
      Was there a clone() class?
      Is there a Library missing?
      Or ??????
      package events
      import flash.events.Event;
      import valueObjects.Product;
      public class ProductEvent extends Event
      public var product:Product;
      public function ProductEvent(product:Product, type:String);
      super(type);
      product = prod;
      public override function clone():Event
      return new ProductEvent(product, type);
      Errors
      Severity and Description Path Resource Location Creation Time Id
      1010: The override attribute may be used only on class property definitions. FlexGrocer/src/events ProductEvent.as line 17 1230044682890 5615
      1020: Method marked override must override another method. FlexGrocer/src/events ProductEvent.as line 17 1230044682896 5616
        • 1. Re: public override clone() -- errors
          Xilian Level 1
          does line 17 refer to this: return new ProductEvent(product, type); ? I guess the compiler is complaining about "type"
          • 2. Re: public override clone() -- errors
            jeffcg2 Level 1
            I commented out that line and get the same errors.
            I'm guessing they have created a custom class that is one of the things I am supposed to get from the CD.
            • 3. Re: public override clone() -- errors
              Level 7
              I think you just have your curly brackets in the wrong place.
              There should be two sets of closing curly brackets after the end of your
              function statement
              (1) close of the class definition
              (2) close of the package
              Note that you have that first one after the end of the constructor.
              HTH;
              Amy
              "jeffcg2" <jeff@holipub.com> wrote in message
              news:gir2ku$cfd$1@forums.macromedia.com...
              > Silver
              > Or ??????
              > package events
              > super(type);
              > product = prod;
              > Errors
              > 5615
              • 4. Re: public override clone() -- errors
                jeffcg2 Level 1
                Thanks you. This works. I had a couple of typos I could not see before also.
                package events
                public function ProductEvent(prod:Product, type:String)
                super(type);
                product = prod;
                • 5. Re: public override clone() -- errors
                  Level 7
                  news:giraae$lj4$1@forums.macromedia.com...
                  > also.
                  > package events
                  > super(type);
                  > product = prod;
                  Did the same thing myself once :-)
                  Now, before I put anything else in a class, I go down to the second curly
                  brace from the bottom and put
                  //end of class
                  That makes sure I don't do it again!
