3 Replies Latest reply on Jul 20, 2017 12:14 AM by Sudha K
    Find Glyph using Unicode
    Sudha K Level 1
           I need to find and change the glyphs using unicode.  When i searching the forum i got the below code.
           Here what is glyphID?  I need to find the glyphs using unicode.  How can i say unicode in the below code?
      app.findGlyphPreferences = null;
      app.changeGlyphPreferences = null;
      app.findGlyphPreferences.glyphID = 0;
      app.findGlyphPreferences.appliedFont = "Font family Name"
      app.findGlyphPreferences.fontStyle = "Font Style Name"
      found = app.activeDocument.findGlyph();
      if (found.length > 0)
      - Sudha K
        • 1. Re: Find Glyph using Unicode
          Ananth@desgin Level 3
          Try this,
          app.findGlyphPreferences = app.changeGlyphPreferences = null;
          //This is example, so please change the fonts and glyphID
          app.findGlyphPreferences.appliedFont = "Minion Pro"
          app.findGlyphPreferences.fontStyle = "Regular"
          //Provide the glyph ID, not the glyph Unicode value.
          app.findGlyphPreferences.glyphID = 366;
          app.changeGlyphPreferences.appliedFont = "Minion Pro"
          app.changeGlyphPreferences.fontStyle = "Regular"
          app.changeGlyphPreferences.glyphID = 240;
          Prabu G
          • 2. Re: Find Glyph using Unicode
            That does not use the Unicode value, it's the glyph index: InDesign ExtendScript API (12.0) . That is not the same thing.
            The option to look for or replace with a Unicode is missing from the scripting engine (since CS3, I might add¹). Report it to Adobe.
            Before someone says: "well it's not a problem because you can always use the regular text find/change or the GREP find/change to search for Unicode characters, like this (piece of code)". Wrong. With these you cannot (1) search for any glyph and replace it with a certain Unicode character, and (2) the other way around, search for a Unicode character and replace it with any glyph. The Glyph Find/Change dialog allows both.
            ¹ Which, if I remember correctly, was the first version in which this dialog appeared. So it's safe to guess "it was never there, and it was never missed in the 7 major versions since then."
            • 3. Re: Find Glyph using Unicode
              Sudha K Level 1
                   Thank you....
                   I have used GID to find and replace glyphs.
              - Sudha K
